Thread: 04 gtp catback
Results 1 to 12 of 12
  1. #1 04 gtp catback
    SE Level Member Porach's Avatar
    United States
    Trying to decide on a good exhaust this time instead of getting a custom exhaust that i redid twice and paid over 200 each time. I need a idea on which cat back i should get. I already have headers, smaller pulleys, and supporting mods.
    I want to get a more expensive catback so it will sound 10x better, and get better flow. My first catback i got when it was stock was 2.5 inch straight pipes that didnt sound very nice. then after i did all my mods the shop put together some crap my friend talked me into getting even want. Which i had a res and muffles. But when i went to the track my y pipe popped off so i have to cut that into pieces so i could get it into the car. And ive been running open headers for a few days now till i get my engine rebuilt.
    So now im looking around at catbacks and zzp has a nice stainless steel 3 inch with magnaflow mufflers on it. Or i could get the slp but its only a 2.5. Need some opinions on what i should get before dropping like 700 on a catback.
  2. #2 Re: 04 gtp catback
    Akron Ohio
    Just get Borla mufflers
  3. #3 Re: 04 gtp catback
    United States
    Is that what you did? I also thought i could do that too with 3inch pipping
  4. #4 Re: 04 gtp catback
    Akron Ohio
    Are you making 500HP? 3 inch pipe isnt going to help anything dont waste the money.
  5. #5 Re: 04 gtp catback
    United States
    Ill have about 450 flywheel hp when im done building my engine. And most muffler shop wont touch my car because im not running a cat on it
  6. #6 Re: 04 gtp catback
    United States
    The universal borla mufflers are +200 per muffler and it would cost around 300 for someone to make me a 2.5 or a 3inch catback. And the shops dont do stainless steel. But if i get it from zzp it would be the same price but for a stainless steel catback
  7. #7 Re: 04 gtp catback
    Catbacks are worthless really.
    Said setup for 400HP?
    Just get a Dynomax Stainless Steel catback...pretty sure they are cheap.
  8. #8 Re: 04 gtp catback
    Bunnell, FL
    so just a tad under 400whp
    I'm a Sex Offender
  9. #9 Re: 04 gtp catback
    Too bad your mystical catback is but a myth.
  10. #10 Re: 04 gtp catback
    United States
    So ya. What should i get? Name brand or zzp?
  11. #11 Re: 04 gtp catback
    My catback went MYSTICAL status? ****, I missed it.
    Quote Originally Posted by Porach View Post
    Have your local exhaust shop just make you one...cheaper.
  12. #12 Re: 04 gtp catback
    Dynomax isn't stainless, its mild steel.
  1. DP to Catback Gasket
    By Explicit_Spade in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-30-2011, 08:36 PM
  2. New Catback
    By NorthernGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-25-2010, 08:05 AM
  3. DIY catback install?
    By IndeedSS in forum General Tech Discussion
    Last Post: 02-26-2008, 12:04 AM
