Thread: separating trans/engine need help
Results 1 to 12 of 12
  1. #1 separating trans/engine need help
    GT Level Member m17davis's Avatar
    Orland Park, IL
    so im trying to pull my motor and i have everything ready to go. i took the 5 bolts off of the trans, and the three bolts off of the flex plate and it will only separate a half inch to a inch. are there dowls on the bottom of the trans or something cause it lifts the whole car if i start to lift it.
    Ported Gen III ~ 3.4 ~ HAI ~ 180stat ~ 605's ~ Speed Daddy's ~ SLP Catback ~ A/C delete ~ Aluminum Sub-frame ~ AGX Coilovers ~ Vinnie Spacers ~ Fusebox & PCM Relocation ~ Wire Tuck
  2. #2 Re: separating trans/engine need help
    GT Level Member t24moore's Avatar
    Feb 2008
    Houston
    Did you remove the ***** bolt? There is a bolt that is fed on the backside under the rear exhaust manifold. You cant see it but you can feel it if you stick you hand behind there,
    Comp Turbo 6765 T4-ST5-A2A IC-Ported Heads-Custom Turbo headers-80 lb inj-F-Body UIM and LIM-AEM WB, TEP trans w 1" chain and Circle D TC, Dual 255s, Bilstien Struts
    WHY IS EVERYONE SO OPPOSED TO DOING A COMPRESSION TEST TO TROUBLESHOOT PROBLEMS?
  3. #3 Re: separating trans/engine need help
    Portland Oregon
    If it's separating at all then he must have gotten the backwards bolt. Get a pry bar in there and pop it off the two dowels
  4. #4 Re: separating trans/engine need help
    Jan 1970
    Maquoketa, Iowa
    Take off the bracket/mount on the passenger side of the trans? Either that or tap on the tc a few times while separating it
  5. #5 Re: separating trans/engine need help
    Orland Park, IL
    so let me get this straight. both the motor and trans mounts have to come out?
  6. #6 Re: separating trans/engine need help
    Florida
    no no no....
    there is a bolt, that is facing the other way through the motor, into the transmission. IE, it goes through the motor, and threads into the tranny. It takes about 3feet worth of extensions to reach.
    If that bolt is out, the you just need to start lifting the motor up, and take a pry bar, and keep prying it loose. Make sure you have something else to wedge in there, like a big screwdriver or something. Eventually it will let loose, and you'll be good to go.
  7. #7 Re: separating trans/engine need help
    Orland Park, IL
    lol. but when im pulling up on the motor the whole car will start to lift
  8. #8 Re: separating trans/engine need help
    Florida
    Yeah, that's because you dont have the engine completely seperated from the tranny. Either that PITA bolt is still on, or the alignment dowels are still holding.
    Orrr...theres a bottom motor mount gettin in the way. Make sure that is unbolted too.
  9. #9 Re: separating trans/engine need help
    Orland Park, IL
    well i got the 4 bolts on the drivers side and the one from the passenger side. the nuts are off of the motor mount. the 3 bolts are off of the flywheel. is that all right? there are only 2 dowels right?
  10. #10 Re: separating trans/engine need help
    Nov 2010
    Atlanta Ga
    and the bracket that holds the trans to the engine? pass side
  11. #11 Re: separating trans/engine need help
    Charles City, IA
    Right behind the power steering pump there are 2 13mm bolts that connect the trans bracket to the engine you need to pull those.
    SMGPFC Two Nipple General
  12. #12 Re: separating trans/engine need help
    Florida
    Yes...theres that...Both times I've pulled mine, I actually pulled all 4 bolts, and removed the bracket to make it easier.
  1. Body Separating?
    By PeterCottonTail in forum General Tech Discussion
    Last Post: 01-28-2010, 09:14 AM
  2. Trans only or Trans + Engine
    By 98GTKen in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-23-2008, 12:01 AM
  3. Running Trans oil as engine oil
    By 04CompG in forum General Tech Discussion
    Last Post: 11-25-2008, 12:09 AM
  4. engine or trans?
    By BankRupt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-01-2008, 05:43 PM
