Thread: hard start
Results 1 to 5 of 5
  1. #1 hard start
    pennsylvania
    I have a 97 gtp when i start it it makes a rough noise then stops. I think its the pulley system when it first turns it turns hard and suggestions?
  2. #2 Re: hard start
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    take the belts off.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  3. #3 Re: hard start
    pennsylvania
    I did just change all the belts cause i thought that was the issue
  4. #4 Re: hard start
    have you tried turning the pulleys to see if any of the bearings feel damaged?
    It could be as simple as your grounds or your starter/battery is getting old.
    Battery being charged?
  5. #5 Re: hard start
    St. Louis
    Could be the A/C compressor. Like it was suggested, take both belts off and start the car for a minute. If the problem goes away then check everything that turns until you find the issue. Just don't run the car long as you are not going to be turning the waterpump or anything else.
  1. Hard to start GTP
    By jcnavalacademy in forum General Tech Discussion
    Last Post: 09-12-2013, 09:00 AM
  2. Hard Start When Cold
    By TheRoadWarrior in forum General Tech Discussion
    Last Post: 04-28-2011, 10:36 PM
  3. hard start issue... PLEASE HELP!!!
    By Jrs1987 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-14-2011, 07:18 AM
  4. Car hard to start.
    By gtp99jlp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-11-2010, 11:44 AM
  5. Car hard to start sometimes.
    By WhiteGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-14-2008, 07:40 PM
