Thread: Steering Wheel Noise?
Results 1 to 6 of 6
  1. #1 Steering Wheel Noise?
    St. Cloud, Minnesota
    I have a 97 gtp that makes a weird noise turning the wheel. I does it when ever i turn it, driving or parked. It sounds like clicking. click click click click. I can hear it outside the car but i have flowmaster 40s so thats probably why. I can hear it inside and feel it a little through the wheel too. Is there something wrong with the rack?
  2. #2 Re: Steering Wheel Noise?
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    maybe bad strut mounts, or bearing plates.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  3. #3 Re: Steering Wheel Noise?
    would that make the noise tho even just sitting in the driveway turning the wheel back and forth. the click go fast or slow depending on how fast i turn the wheel if that helps at all
  4. #4 Re: Steering Wheel Noise?
    Donating Users NoBoost91's Avatar
    Queens, New York
    im pretty sure that noise is common, i heard its just the steering knuckle needs to be re-greased
  5. #5 Re: Steering Wheel Noise?
    Mercer, Pa
    Intermediate splined shaft needs taken out and greased. Fill tube with grease put rubber cork in end and compress. Refill tube with grease and reinstall. Do not turn the steering wheel during this or you will screw up stability system. Search intermediate shaft and get lube kit from dealer.
  6. #6 Re: Steering Wheel Noise?
    thanks i'll check it out
  1. Noise coming from steering wheel????
    By jmack98 in forum General Tech Discussion
    Last Post: 04-26-2011, 05:41 PM
  2. steering wheel help
    By ham4864 in forum General Tech Discussion
    Last Post: 11-27-2010, 07:32 AM
  3. Steering wheel...
    By SiDeWaYz in forum Visual/Body Modifications
    Last Post: 07-21-2010, 10:45 PM
  4. Steering Wheel
    By RideMr2 in forum General Tech Discussion
    Last Post: 05-27-2010, 11:41 PM
  5. steering wheel
    By Dawings33 in forum 04+ Specifics
    Last Post: 06-26-2009, 02:37 AM
