Thread: GTP Starts and dies after 4-5 seconds, revving the engine keeps it running
Results 1 to 15 of 15
  1. #1 GTP Starts and dies after 4-5 seconds, revving the engine keeps it running
    Apr 2011
    US
    Hi All,
    I have a 1997 4 door GTP that will start and run for about 4-5 seconds and then stumbles and dies. If you apply the throttle and rev it a bit, it will run but if you let off the throttle it dies.
    Video of it running here (and dying) here:
    YouTube - 1997 Grand Prix GTP
    Any thoughts here?
    Thanks!
  2. #2 Re: GTP Starts and dies after 4-5 seconds, revving the engine keeps it running
    Sounds like (can't see vid at work) it's either a maf sensor or IAC. Try unplugging the MAF and helping it stay running for a couple of min. Then see if it idles on it's own.
  3. #3 Re: GTP Starts and dies after 4-5 seconds, revving the engine keeps it running
    Apr 2011
    US
    Side Note: CEL is NOT on.
    Thanks!
  4. #4 Re: GTP Starts and dies after 4-5 seconds, revving the engine keeps it running
    That only means either it's pending or the pcm doesn't see the issue. It's amazing how much our pcm's can't see when we notice an obvious issue.
  5. #5 Re: GTP Starts and dies after 4-5 seconds, revving the engine keeps it running
    Apr 2011
    US
    Will do. I will try this later today and report back -Thanks!
  6. #6 Re: GTP Starts and dies after 4-5 seconds, revving the engine keeps it running
    Apr 2011
    US
    Noted. Thanks
  7. #7 Re: GTP Starts and dies after 4-5 seconds, revving the engine keeps it running
    GTX Level Member real diehl's Avatar
    Salina, KS
    I would've said MAF as well. This was the problem with my sisters car.
    signature removed for inappropriate content.
    -bio
  8. #8 Re: GTP Starts and dies after 4-5 seconds, revving the engine keeps it running
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Had the exact same problem. Cleaned the MAF and IAC valve and it fixed it.
  9. #9 Re: GTP Starts and dies after 4-5 seconds, revving the engine keeps it running
    Apr 2011
    US
    Another side note: The problem developed while cruising at 70mph on the freeway. All of the sudden the engine died and acted as it does now. (as opposed to a condition that gradually developed over time). Just in case that helps
  10. #10 Re: GTP Starts and dies after 4-5 seconds, revving the engine keeps it running
    Apr 2011
    US
    NEW IMPORTANT NOTES:
    I originally though that if you rev the engine it would stay running, it DOES NOT help to rev the engine, it still dies after 5-6 seconds. Sorry for the misinformation, that is an error on my part. -Oops!
    I have cleaned the MAF and IAC and it did not help.
    On a side note, the Service Engine Soon light does come on with the MAF unplugged.
    I also seem to hear the fuel pump stop running after cranking the engine, it then runs for about 2 seconds after the engine dies. Is this normal, does it have something to do with the resistor issues?
  11. #11 Re: GTP Starts and dies after 4-5 seconds, revving the engine keeps it running
    Apr 2011
    US
    UPDATE:
    After some digging through posts/threads on the forum, I decided to try the fuel pump resistor bypass. It worked so we're good to go!
    Thanks to all for their thoughts on this issue
  12. #12 Re: GTP Starts and dies after 4-5 seconds, revving the engine keeps it running
    Topeka, KS
    Glad you got it fixed and your Avatar cracks me up. LOL.
  13. #13 Re: GTP Starts and dies after 4-5 seconds, revving the engine keeps it running
    Apr 2011
    US
    Thanks, this repair was pretty painless
  14. #14 Re: GTP Starts and dies after 4-5 seconds, revving the engine keeps it running
    I was going to say that..but you originally thought it would stay running. C'mon man... ya gave us some bogus info...lol
    Glad you got it fixed up.
  15. #15 Re: GTP Starts and dies after 4-5 seconds, revving the engine keeps it running
    Apr 2011
    US
    Yep, sorry about that!
  1. Car starts then dies
    By Rocket468 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2011, 01:08 AM
  2. Car shuts off after a few seconds of running
    By Kissner in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-17-2010, 10:51 PM
  3. 97 gtp starts but dies
    By 50trimomni in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-26-2010, 04:20 PM
  4. Car starts but stalls after 2 seconds
    By cartooz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2009, 06:18 AM
  5. HELP: Starts then dies after LIM
    By rfmgtp02 in forum General Tech Discussion
    Last Post: 06-23-2009, 03:35 PM
