Thread: Tranny pan gasket and RTV
Results 1 to 14 of 14
  1. #1 Tranny pan gasket and RTV
    Vancouver, WA
    I was told by a member on a different forum that I shouldn't use RTV on the tranny pan gasket because the tranny fluid would eat down the RTV and it would clog the valve body. If the RTV gets broke down wouldn't the filter stop any pieces from getting to the valve body of through the tranny at all? I'm being told just to change the fluid and filter but I just did it a couple months ago. Input appreciated. Thanks.
    Slowest 'Cooled Gen V ever
  2. #2 Re: Tranny pan gasket and RTV
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    As far as I know the pan gasket is sufficient. No need for RTV.
  3. #3 Re: Tranny pan gasket and RTV
    Vancouver, WA
    It's already been done lol.
  4. #4 Re: Tranny pan gasket and RTV
    Waukesha, WI
    i think the rule of thumb is...if its paper type use rtv, if its rubber dont
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  5. #5 Re: Tranny pan gasket and RTV
    Vancouver, WA
    It's rubber :/
  6. #6 Re: Tranny pan gasket and RTV
    Waukesha, WI
    i doubt tranny fluid will "eat" rtv.. dont worry about it lol
    RayRay
    92 Turbo miata
    02 lexus is300
  7. #7 Re: Tranny pan gasket and RTV
    Vancouver, WA
    Well his exact works were that it would break it down.
  8. #8 Re: Tranny pan gasket and RTV
    Pennsylvania
    Well tranny fluid has some detergents in it, doesnt it? It could possibly break down the rtv... just sayin it's possible, I dont know for sure.
    That being said, I've never heard of RTV being used on a tranny pan, Im pretty sure the gasket is enough..
    I have heard people say to get a stock replacement though, and not to use the junky one that comes with a filter kit, or reuse the reusable one that is on your pan from the factory, if it's not damaged.
    None of the write ups and even the directions for drain and refill on the filter kit box mention rtv or any kind of sealant, just the gasket.
  9. #9 Re: Tranny pan gasket and RTV
    people have used rtv on trans pan gaskets forever, dont worry about it. the only thing is, you will probably never get the gasket off in one piece down the road.
  10. #10 Re: Tranny pan gasket and RTV
    I doubt it would break down or leak if you use a good RTV. However being that you want to remove that pan to service the trans at times. The best gasket is the factory gasket. It's considered a lifetime gasket, has ribs and metal in it. It's a great gasket.
  11. #11 Re: Tranny pan gasket and RTV
    SE Level Member postalc38's Avatar
    Brant, Michigan, United States
    ALOT of Chrysler/Dodge cars come from the factory with RTV'ed transmission pans. Caravan/Intrepid/Stratus and some other FWD transmissions.
    Yeah, i've seen some come into work leaking........But they also had upwards of 100K miles and if you haven't taken care of the trans filter by then it SHOULD give out just so you have to do it....lol
    2000 GP - 157K (DD/Crash damaged project)
    1995 Olds Aurora L47 - 222K
  12. #12 Re: Tranny pan gasket and RTV
    Vancouver, WA
    Thanks for the input guys. I am still using the stock rubber gasket, I just put some RTV on for a lil extra sealing precaution.
  13. #13 Re: Tranny pan gasket and RTV
    Wichita, KS
    Stock metal reinforced gasket can be cleaned and reused dry. I would NEVER do RTV on a transmission pan just for the mess it creates, and taking the time to clean up all that before you can reinstall the pan each time you do a pan drop filter/fluid change.
    If you didn't have a issue before, why even add RTV.
    I will how ever do RTV on our oil pan gaskets, cause your not taking those off every 50K miles. Plus, that's the ONLY way to insure its a job well done so your don't have leaks.
    ~F~
  14. #14 Re: Tranny pan gasket and RTV
    oil pan gasket also seals the front cover so its a good idea considering its sealing at least three pieces. (unsure of rear cover)
  1. Oil pan gasket
    By Jochen in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-22-2012, 10:23 PM
  2. LIM Gasket, Head Gasket, or bad sensor?
    By GTFiske in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2010, 08:40 PM
  3. Tranny Filter Gasket
    By SDGTP99 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-13-2009, 03:41 AM
  4. Oil Pan Gasket
    By JJ91284 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2009, 10:03 PM
  5. Gasket Kit
    By 03GPScottyd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2009, 01:09 PM
