Thread: gtp problems
Results 1 to 4 of 4
  1. #1 gtp problems
    memphis tn
    Ok I have I 04gtp and when I start it up it runs fine but when it warms up I'm hearing a loud grinding vibrating kinda noise its loud as hell so I replaced the sc tension pulley and top sc idler pulley not the bottom one noise still there so I take the belt off the sc and the noise is gone and wit the sc belt off I step on the gas the sc pulley spins fast then just stops spinning with the belt on sc works fine boost is normal it really sounds like to me the tension on the motor not the pulley the whole tension I put a screw driver to it and it sounded rough I changed that pulley still same noise but I know it can't be that cause when the sc belt is off I don't hear it somebody Helllllp!!!!
  2. #2 Re: gtp problems
    put the screw driver on the supercharger case itself and on the snout, and listen for the noise, if it sounds like rocks banging around, then its the coupler in the supercharger that went bad.
  3. #3 Re: gtp problems
    memphis tn
    I did that it sounds smooth
  4. #4 Re: gtp problems
    memphis tn
    Imma upload a video in a lil while
  1. you think you got problems
    By avelate63 in forum The Rant Forum
    Last Post: 07-30-2010, 01:58 AM
  2. HID problems AGAIN
    By lilbear6889 in forum Visual/Body Modifications
    Last Post: 07-26-2010, 07:12 AM
  3. MAF problems (i think) HELP!
    By Nig Gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2010, 06:31 PM
  4. NEW GUY NEW Problems!?
    By 06GPNA3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-08-2009, 11:43 PM
  5. More problems?!?!?!?!?
    By kingbrentdwyer in forum General Tech Discussion
    Last Post: 11-01-2008, 01:09 AM
