Ok I need some ideas on why I might be having KR. I get 2 Kr from 5200 RPM up in second gear. I have 10 lbs max of boost, 11.7 AFR with wideband and trying for 19 degrees timing, drops to 17 with Kr.
Mods are
65 lb injectors
255 walbro
1.9 modded rockers
zzp Headers
zzp Fullsize intercooler
Wideband
Monte carlo dual exhaust
72mm tb
Ported supercharger
As far as I can tell I have no valve float. Maf airflow is around 285g/sec which is around what it should be making.
From what Ive been reading on here and other forums I should have no problem running a 3.0 pulley.
