Thread: so... I think I broke it...
Results 1 to 20 of 32
  1. #1 so... I think I broke it...
    Omaha, NE
    I finished my topswap and went to start the car today. It fired up ok, pretty much what I was expecting with the cam, but now I have an audible knock. It seems to be coming from the back of the eninge, but idk for sure. Its not steady, its got a very random sequence.
    I torqued the stock roller rockers to the torque specs provided on the GM service manual. The lifters are properly seated.
    My tune is very very close to the 3.4 pulley, autolite 104, 9" cone filter tune from the HPTuners repository.
    I have a couple of scans if anybody wanted to take a look at those.
    Anybody have any ideas?
  2. #2 Re: so... I think I broke it...
    Jan 2009
    Tallahassee, FL
    header hitting the sway bar?
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  3. #3 Re: so... I think I broke it...
    Omaha, NE
    I don't think that's it, but I'll look to be sure.
    I haven't driven the car, just fired it up and let it idle a few minutes.
  4. #4 Re: so... I think I broke it...
    a few minutes? did you let it idle long enough for the lifters to pump up and get back to good?
  5. #5 Re: so... I think I broke it...
    get a video spadey...
  6. #6 Re: so... I think I broke it...
    Banned
    Sioux Falls, SD
    Before i started mine i left the fuel pump fues out and cranked it over a couple times just to get oil on everything and lifters pumped back up
  7. #7 Re: so... I think I broke it...
    Or just plug the ICM...
  8. #8 Re: so... I think I broke it...
    Omaha, NE
    I shut it off after it would knock a few times. Is it normal to hear loud knocks while things are breaking in?
    I took some videos, and I'll upload those shortly.
  9. #9 Re: so... I think I broke it...
    lifters knock pretty loud when they arent pumped up...i know it freaked me out the first time...
  10. #10 Re: so... I think I broke it...
    Omaha, NE
    That may be what it is. I guess I'll give it some more time. Is there anything special I should to to get them to pump?
    Videos are uploading slowly on youtube.
  11. #11 Re: so... I think I broke it...
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Unplug the ICM and prime the engine 40 sec at a time. I usually do this 10 times or so.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  12. #12 Re: so... I think I broke it...
    Quote Originally Posted by 01gpgt01 View Post
    Told ya so...
    DUH.
  13. #13 Re: so... I think I broke it...
    Kansas
    let the car idle
    SOLD 1999 GT Silvermist TS
  14. #14 Re: so... I think I broke it...
    Akron Ohio
    Video?
  15. #15 Re: so... I think I broke it...
    I think he died.
  16. #16 Re: so... I think I broke it...
    Grand Island, Nebraska
    Im feeling like its a bad idea to do a topswap in NE.
  17. #17 Re: so... I think I broke it...
    Omaha, NE
    NE topswaps are just bad news all around.
    I think he died.
    My friends said that on my FB status.
    Heres the few quick videos I took earlier. 2&3 you can hear the knock better
    YouTube - GOPR0146
    YouTube - GOPR0147
    YouTube - GOPR0148
    I drove it to the gas station and its a lot better, but still needs a tune BAD. and I apparently put in a coolant elbow wrong and smashed an o ring, so that's out. Also, I did get the supercharger belt tight.
  18. #18 Re: so... I think I broke it...
    Jersey
    how is top swapping a bad idea?
    your s/c belt shouldn't be jumping like that.
    did you torque your rocker bolts when the rockers were tdc?
    are u using the right s/c belt?
    did you align your timing marks properly?
    did you torque the cam bolt properly?
    are your spark plug wires in the right order?
    i would start with those, what do your spark plugs look like? oh and post your scans
    16' wrx sti- stock
  19. #19 Re: so... I think I broke it...
    Quote Originally Posted by 99prixgt View Post
    It was a joke, the last 2 people in Nebraska (including spade) have had problems getting them working correctly. the first one was done months ago and still isnt 100% im next....
  20. #20 Re: so... I think I broke it...
    spade is silly and was making a big deal out of his lifters not being oiled up. the car quieted down after he let it idle a little bit, just like they all do.
  1. I broke it!!!!! :-(
    By klj5022 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2011, 09:01 PM
  2. Need help! Think i broke the warden's car
    By Glider Girl in forum General Tech Discussion
    Last Post: 11-26-2010, 12:40 AM
  3. What Broke?
    By 1quikgp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-16-2010, 07:47 PM
  4. Think I broke something...
    By BwolfGT in forum Off Topic Discussion
    Last Post: 11-12-2009, 08:01 PM
  5. I broke it!
    By The_Avenger in forum General Tech Discussion
    Last Post: 07-27-2008, 09:31 AM
