Thread: cam help
Results 1 to 5 of 5
  1. #1 cam help
    Jul 2010
    orefield pa
    i have the engine out of my 97 gtp right now changing out some gaskets and just cleaning it up and i thought while i have it out maybe i'll put a cam in it what is the best bang for the buck as far as cams go with minimal changes to the rest of the engine ?
  2. #2 Re: cam help
    http://www.grandprixforums.net/safel...car-17482.html
    Since they are all pretty much the same price...
  3. #3 Re: cam help
    GTX Level Member Juanmiguel's Avatar
    Mexico
    They all cost about the same. If you want to go strictly by the cheapest option, then go for a VS cam. you don't necessarily have to change the rest of the valve train components in order to run it.
  4. #4 Re: cam help
    Jacksonville, Fl
    X2 on the VS cam.
    I'd suggest springs and retainers with it. But you don't necessarily need them.
  5. #5 Re: cam help
    Supposedly Vs means valve train safe. However if you listen to that... you are making a huge mistake.
    Do the springs for any cam. Please.
cam
