Thread: Pictures of Modified SD Headers (using jig)
Page 3 of 3 FirstFirst 123
Results 41 to 58 of 58
  1. #41 Re: Pictures of Modified SD Headers (using jig)
    MA
    hey max,
    remember when you said youd make one for me? i do
    SMGPFC Member #9
  2. #42 Re: Pictures of Modified SD Headers (using jig)
    Quincy, Mass
    Quote Originally Posted by Silver GTP View Post
    I made the jig that Max used. It was easy to make. Assemble the rear header and downpipe. Lay it on a strip of plywood and measure the angles at both ends. Cut a block of wood for each end that matches the angles. Lag the blocks onto each end of the pipe. Screw through the plywood into the blocks to hold it down. I used half inch plywood so a scrap strip of wood was attached to make it more rigid. Measure the angles under the pipes and cut pieces of wood that match. This will be your guide for where the floor of the car will be. Attach them to the jig. With both ends of the pipe attached, you can now cut the middle out and piece back together the way you want it. Tack weld it together then remove from the jig and finish welding.
    well the problem for me is, my headers are used and the first person the put them together didnt do it right and the flex is where the bend is. i was hoping for the angles so i could have the dp redone the right way. i have slp headers tho so it might not be the same.
    No more GP 04 Impala SS Indy:
  3. #43 Re: Pictures of Modified SD Headers (using jig)
    Donating Users
    South Deerfield, MA
    Quote Originally Posted by Swiggles View Post
    You could follow the same idea. You know your rear header and downpipe fit in the car right now. Remove them from the car and then build the jig around them the same as I did with mine. If you know where the ends will be, you just need to have them secured in place while you cut the middle out and rebuild it the way you want.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  4. #44 Re: Pictures of Modified SD Headers (using jig)
    Ottawa ON, Canada
    That depends on you. Give them my write up on how to install them and they'll zip right through it in 3-6 hours.
    im gatherin part names and stuff like clamps and the flex etc that i need,
    but to find a deecent write up that i could give to a shop? anyone care to help :P
    _______________________
    2002 Acura Rsx Type S - K20A2
  5. #45 Re: Pictures of Modified SD Headers (using jig)
    Quote Originally Posted by GrandPrixGTP1 View Post
    I'm going to be a dick. Guess you couldn't find or work the search button? C'mon guy.. we are here to help, not do all the work for you.
    Searched on "Header Install" with username "BillBoost37" (because I suggested using the write up that I did). The third thing in the search was sitting in the "How To" section.
    http://www.grandprixforums.net/how-i...hod-44126.html
  6. #46 Re: Pictures of Modified SD Headers (using jig)
    Quincy, Mass
    you should give them pics of the rear header from this page too.
    its a 4-8hour (3-6 if you follow bills write up) job so ur going to pay a shop an a$$ load for the install. theyre not hard to do on your own with the help of a local whos done them before.
  7. #47 Re: Pictures of Modified SD Headers (using jig)
    Wichita, KS
    I like how the pool cues are mounted in the recessed built in cubby in the wall. Pretty cool.
    Now, get the stuff off the pool table, and on the car.
    ~F~
  8. #48 Re: Pictures of Modified SD Headers (using jig)
    Florida
    does anyone have any before and after pictures on the car? just wondering how far down on the GP's and 6th gen monte that the DP stuck before and after chopping it up. I modified my fire wall and the headers fit but the down pipe looks very low.
  9. #49 Re: Pictures of Modified SD Headers (using jig)
    Yes..tons of pics..just search
  10. #50 Re: Pictures of Modified SD Headers (using jig)
    Florida
    ok after tons of searching all i found so far is this and it looks modified to me ...
    from this thread: http://www.grandprixforums.net/final...s-3-47858.html
    if that is how they all hang then i might be having issues :-X
  11. #51 Re: Pictures of Modified SD Headers (using jig)
    Where is this jig now LOL
  12. #52 Re: Pictures of Modified SD Headers (using jig)
    MA
    hes actually got these headers for sale.. unless they already sold
    SMGPFC Member #9
  13. #53 Re: Pictures of Modified SD Headers (using jig)
    SilverGTP or Intrigue?
    Bunnell, FL
    Looks like mine except mine is fully welded and black
    Android Fire
    I'm a Sex Offender
  15. #55 Re: Pictures of Modified SD Headers (using jig)
    GT Level Member Dtrick22's Avatar
    Jul 2010
    Holyoke, MA
    Quote Originally Posted by Drunkie View Post
    Intrigue98
    2006 GT- S1x, 3.25 MPS, Lucas 42.5, MAF, SD Headers, C5 Brakes, AGX/Vogtland, GMPP sways
    Quote Originally Posted by Wotgtp View Post
    I eat, drink, sleep, and masterbate to grand prix's. Come at me bro.
  16. #56 Re: Pictures of Modified SD Headers (using jig)
    May 2012
    Burlington, Wisconsin
    How did you modify the u pipe so it is straight?
    1998 GTP Sedan: Gen III, Speedy Daddy Headers, SLP Catback, Magnaflow High Flow Cat, Open Cone Intake, Autolite 104s, Debadged, more to come!
  17. #57 Re: Pictures of Modified SD Headers (using jig)
    Quote Originally Posted by Btownmills View Post
    I don't understand the question. It was cut and rewelded.
  18. #58 Re: Pictures of Modified SD Headers (using jig)
    May 2012
    That's the answer I was looking for.
  1. Modified exhaust??
    By qksilver in forum The Rant Forum
    Last Post: 12-02-2010, 11:37 AM
  2. Modified '97 TB?
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-08-2008, 10:57 PM
