Thread: Lazy Boost
Results 1 to 19 of 19
  1. #1 Lazy Boost
    Wichita
    Really it is. I barely touch the gas and the boost gauge lights up. I can here the supercharger but I sure as **** cant feel any boost. I have to mash the gas to feel any boost at all. Im assuming vacuum leak, BBV isn't closing, bad tune or something else. I just don't know. Blah...
  2. #2 Re: Lazy Boost
    bad map? you shouldnt see boost that quickly
  3. #3 Re: Lazy Boost
    Omaha, NE
    Stock tune?
  4. #4 Re: Lazy Boost
    Wichita
    Nvm. When I popped my hood to hook my boost gauge back up I Found s/c oil all over the s/c. That was vacuum leak pt1. I also discovered thr was a third line on the boost bypass solenoid that had nothing connected to it so I capped it of. That was vacuum leak pt2. Is anything bes iyd es the bbv and fuel line vacuume supposed to be connected to that?
  5. #5 Re: Lazy Boost
    Houston
    Mine goes from here
    To here
    ^this is at the heater core inside the car, passenger side, behind the center console
  6. #6 Re: Lazy Boost
    Wichita
    Im not going to edit that to fix my typo. I'll leave it there for you all to figure out.
  7. #7 Re: Lazy Boost
    Wichita
    The BBS is the small cylinder just below the BBV.
  8. #8 Re: Lazy Boost
    Wichita
    Well. If that missing line was supposed to connect to the inside accessories like the aircon then that woud explain why my dual aircon dosent work right....cuz thrs no vacuum line goin to it. Hrm...
  9. #9 Re: Lazy Boost
    Houston
    Yeah....it wont blow for chit, and will have issues switching levels.
  10. #10 Re: Lazy Boost
    Wichita
    Yes I have that problem. Are there two lines then that go to the hvac? The line on top of my s/c is connected. Its the line on the bypass solenoid that isn't
  11. #11 Re: Lazy Boost
    Houston
    There is just the one going into the car. I believe the other one runs to the HVAC controls. I dont have muh car here to verify right now. I only have two lines goin to the bbs, one in from the bbv and out to the vac manifold. Pay no attention to the circle...for another post
  12. #12 Re: Lazy Boost
    Wichita
    On that diagram. Number 7. Top right. That is an open port with nothing connected too it. I capped it off now the car runs great.
  13. #13 Re: Lazy Boost
    Houston
    Yeah, the diagram looks like its showing it capped. I'll have to look under my hood to see. I should get my car back tomorrow.
  14. #14 Re: Lazy Boost
    Wichita
    Alrighty if it is capped that tells me I did fix a big problem.
  15. #15 Re: Lazy Boost
    #7 should have a side open to the atmosphere...if it is capped then you might have an issue.
  16. #16 Re: Lazy Boost
    Wichita
    Your probably right. But, when I capped that off it fixed my boost issue. I have no issues at all now.
  17. #17 Re: Lazy Boost
    GTX Level Member tayl5645's Avatar
    Jul 2010
    Michigan
    Yeah idk about open. I know what your saying and I was working under there yesterday and mine is capped too. Stock
    2005 GTP Grey
    Custom built Open cone intake, 15% tints all the way around, 7" touchscreen DVD player
  18. #18 Re: Lazy Boost
    Probably because you have a vacuum leak elsewhere.
  19. #19 Re: Lazy Boost
    Quincy, Mass
    that should have a small piece of foam as a filter on it not capped. if your vents arent working then you still have a leak somewhere.
    No more GP 04 Impala SS Indy:
  1. Driverside seat recliner is lazy..
    By ryepsboe in forum General Tech Discussion
    Last Post: 03-15-2011, 09:36 PM
  2. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  3. Greetings from The Lazy R !!!
    By thelazyr in forum Introductions/Noob Questions
    Last Post: 08-27-2010, 06:21 PM
  4. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
