Yes bio i know wrong spot to post, But i need help ASAP really bad.
Coolant issue leak issue, Okay guys, It wasn't my throttle body spacer, I checked, I got the blower off It wasn't the Yellow orings leaking, I made sure, i checked the PCV system and its soaked with coolant and oil, And so is the inside of the intake manifold, I pressure tested the blower with my mouth (EEEW) and all the ports are sealed nicely. No coolant ports leak air.
Is my intake manifold to blame then? i dont want to go through the trouble of blocking off the 2 coolant ports to find out its no good, Why is this leaking at the PCV? i took it out and it still checks out good, it rattles lol, And i blew it out and brake cleaner'd it,
sad part is i can't find my original Intake manifold and I cant get any in the junkyards another thing is i bought this intake gasket matched.... could he of screwed something up? i really really don't want to have to pull the intake off being i'll need coolant and another oil change and moneys tight right now
