Thread: Talk to me guys. Turbo for my comp g
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 69
  1. #1 Talk to me guys. Turbo for my comp g
    GTX Level Member colindunn's Avatar
    Aurora, IL
    Either the z7 or z3 kit? Id like to twincharge.. Its gonna happen but id love some more info from people that know a bit more about turbos. And what id have to do
  2. #2 Re: Talk to me guys. Turbo for my comp g
    Meh on the twincharge...sell off your blower crap and make a good amount of money back for a simple z3 build. 400 FWHP...easy.
  3. #3 Re: Talk to me guys. Turbo for my comp g
    Aurora, IL
    What would I have to build on my motor? I could gey decent money since I jave a gen v blower. But I still love the blower sound. Just looking at my options
  4. #4 Re: Talk to me guys. Turbo for my comp g
    I hear ya...
    I bet you could sell a GenV Top Swap for over $500 easy to an '04+ owner. Even a non-intercooled Z3 kit under 10psi will make great numbers...an intercooler will do even better...which honestly I wouldn't NOT run an IC with a snail...so beneficial. If I could do it all over again...I'd snail it. I've got the transmission for it...why not
    On the motor...you really don't NEED anything...you can run a stock cam/stock rockers...I figure that since your there rockers would be a great upgrade and you really don't have to "tear" into anything or build a motor minus removing the valve covers. 1.80:1 ratio ones don't even need stronger valve springs. If I was to snail a car...I'd get ported heads, a big cam...and a bulletproof valvetrain and run a pretty good sized snail on it with a big stall.
    That's just me though.
  5. #5 Re: Talk to me guys. Turbo for my comp g
    Aurora, IL
    I want rockers. Idk about the sc. dont I need that throttle body though? Will it bolt up to an older sc?
  6. #6 Re: Talk to me guys. Turbo for my comp g
    With an adapter plate yes...I'd get an Aluminum L26 Upper Intake with an HV3 and Rockers...with a turbo build that thing should easily run 12's on street tires with a good tune...
  7. #7 Re: Talk to me guys. Turbo for my comp g
    Aurora, IL
    Would I need a different lim too then?
  8. #8 Re: Talk to me guys. Turbo for my comp g
    GTP Level Member
    Pittsburgh
    all this talk with out any mention of a trans.....
    Build a trans first then Turbo
    2003 SSEi,
  9. #9 Re: Talk to me guys. Turbo for my comp g
    Quote Originally Posted by 2003 SSEi View Post
    Because a base Z3 kit is intended for those people with a stock transmission...or that aren't making tons of power. I've seen plenty of turbo kits without a built transmission still make good numbers and run good times. Is a built trans required...no...is it a good investment...beyond belief.
  10. #10 Re: Talk to me guys. Turbo for my comp g
    Aurora, IL
    Im not making this a race car I just wamt a turbo. Even if it makes the same or a little more than a 3.4 setup
  11. #11 Re: Talk to me guys. Turbo for my comp g
    A turbo kit of any kind makes a 3.4" setup look stupid slow
  12. #12 Re: Talk to me guys. Turbo for my comp g
    Aurora, IL
    Does it really? How while making the same boost?
  13. #13 Re: Talk to me guys. Turbo for my comp g
    Efficiency brutha...turbo is not taking power from the motor to make power like a roots type blower...your making power off of spent exhaust gases
  14. #14 Re: Talk to me guys. Turbo for my comp g
    Aurora, IL
    Its just so much moremomey than a 3.4 setup though
  15. #15 Re: Talk to me guys. Turbo for my comp g
    SE Level Member Mike Kopstain's Avatar
    Chicago, IL
    Twincharging really only has a tangible benefit for a track car in that you can use a larger turbo for more power and rely on the blower for low end torque (and quicker spooling). For a street/ fun car I can't see the need and the setup is exponentially more complicated.
    I run a Z3 kit on my car. Yes, I know that sounds odd. We had a full prototype kit on my car, I pulled it off to have it made and put on a used Z3 kit back on. Unfortunately we ultimately decided that the market won't take another turbo kit and that ZZP has that market pretty well cornered so the idea was shelved. But I digress!
    We have essentially the same car (04 Comp G). I'm running the Z3 with the small turbo and small intercooler and I'm pushing it through a bone stock exhaust for 339whp at 14lbs. Basically it's as tame as you can get but still completely ridiculous on the street. ZZP makes a good kit. We sold Cartuning back in the day and besides the kit being lackluster, Kevin's customer service also SUUUUUUCCCKKKKED.
    As for the difference between a turbo and supercharged setup, I wouldn't call either better. Both feel completely different, even at the same power level. I'm casually looking to buy up one of the retired drag cars to build another blower setup. Nothing sounds quite as wicked as a lopey cammed 3.8 with an obnoxiously loud blower.
    Thinking about shopping with ZZP or the other guys? - Order with us instead and we'll give you a 5% off coupon code for your next order! Click here to learn how!
    Like us on Facebook!
  16. #16 Re: Talk to me guys. Turbo for my comp g
    Denver
    Sure it is. If it wasnt it would violate the first law of thermodynamics (and every powerplant in the world would have infinite streams of serial turbines running off of exhaust stacks creating power without cost).
    The work done by the turbo requires energy (taken from the exhaust stream) and ultimately from the engine itself via increased backpressure.
    The sc vs turbo is an efficiency debate (as you alluded to).
    To the OP - there are a million articles available about forced induction choices. There are sc guys and there are turbo guys - but the both do fundamentally the same thing: they use engine power (directly or indirectly) to compress incoming air so that more fuel can be shoved into the intake and burned (creating more power).
  17. #17 Re: Talk to me guys. Turbo for my comp g
    GTX Level Member Confusingboat's Avatar
    Minnesota
    Quote Originally Posted by SJAndrew View Post
    Turbocharger > supercharger. Don't even go there.
    2004 Grand Prix GT2 - SOLD
    2015 Evo MR
  18. #18 Re: Talk to me guys. Turbo for my comp g
    Denver
    Quote Originally Posted by Confusingboat View Post
    My point was that the turbo boost isn't free - that would be energy generation which flies in the face of physics and reality.
  19. #19 Re: Talk to me guys. Turbo for my comp g
    GT Level Member VictorSmalls's Avatar
    Dec 2008
    Tyrone, PA
    Lets not get off point here. I think he was trying to say that a blower takes power from the engine to run, when a turbo essentially uses engine waste to create power. Sure it uses engine power to run a turbo in the form of back pressure and heat, but the point is that a turbo doesn't use nearly the amount of power from an engine as a blower does.
    Retired
    Turbo'd
  20. #20 Re: Talk to me guys. Turbo for my comp g
    Aurora, IL
    i love the sound of a supercharger. but i would have to be intercooled to run below a 3.6 inch pulley. i also would love to cam it. but the install wuldnt be easy. a turbo kit is more money, but there is something to be said about a turbo'ed 3800 also.. very hard decision. lol
  1. Don't Talk Sh!T
    By KawaFord in forum Off Topic Discussion
    Last Post: 11-26-2010, 11:41 AM
  2. Talk about a bad day
    By Deimos in forum Off Topic Discussion
    Last Post: 02-04-2010, 09:32 AM
  3. Replies: 0
    Last Post: 11-07-2009, 06:30 PM
  4. Wow, can we talk her into buying a GTP
    By 03GPScottyd in forum Off Topic Discussion
    Last Post: 11-08-2008, 10:14 AM
