Thread: Spark Plug Wires
Results 1 to 7 of 7
  1. #1 Spark Plug Wires
    GT Level Member fri3dchick3n's Avatar
    Alaska
    I recently changed out my spark plug wires and only now noticed that they are 7mm. I was reading random threads just to learn a little more about what I really need to mod a little. I think in the Canadian Guy's signature was safely modding your car link and it mentions spark plug wire ranges from 8mm - 10mm. I have a feeling that I will need to replace them to a bigger range eventually. My mods are: Air Intake, Shift kit. Will 7mm be ok to run with minor mods?
  2. #2 Re: Spark Plug Wires
    yup your perfectly fine.
  3. #3 Re: Spark Plug Wires
    Charles City, IA
    Yeah they will be fine. There is no need for huge wires on these cars. I have 10.4mm tho just to be a baller.
    SMGPFC Two Nipple General
  4. #4 Re: Spark Plug Wires
    GTP Level Member AjL227's Avatar
    IL
    I'm running stock wires on my cam'd Comp G. Don't waste your money, it's mostly an appearance modification.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  5. #5 Re: Spark Plug Wires
    as long as they have a lifetime warranty they should be good.
  6. #6 Re: Spark Plug Wires
    Alaska
    They are AC Delco's. They are grey lol. Not so much on the appearence side. : \ And cost $77 -.-
    99 GTP: 3.4'' MPS, Overkill PCM, Intake, Catless SD Headers, TransGo Shift Kit, 180ยบ Thermostat, Flipped Dog Bones
  7. #7 Re: Spark Plug Wires
    SWPA
    There are some wires that are advertised as 10 mm, when in reality they are 7mm with heavier insulation to make them look bigger.
    I run 8mm MSD's on my Stealth. That's the usual wire most guys in that platform run, and there are several guys in the 700hp range.
  1. Spark PLug Wires
    By 99silvergtp in forum Off Topic Discussion
    Last Post: 12-15-2009, 09:53 PM
  2. spark plug wires
    By izup69 in forum 04+ Specifics
    Last Post: 12-04-2009, 07:32 PM
  3. Spark plug wires!
    By gonzo915gp in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-22-2009, 11:14 PM
  4. spark plug wires
    By jaysongt85 in forum General Tech Discussion
    Last Post: 05-28-2009, 02:30 PM
