Thread: Having some issues with our recently purchased car. Please help.
Results 1 to 20 of 33
  1. #1 Re: Having some issues with our recently purchased car. Please help.
    SE Level Member mngtp's Avatar
    Crystal, MN
    The arm is flat when the engine is off. But when the engine is running it is verticle. When the engine is reved the arm moves, but doesnt go all the way flat. How do I adjust the arm if that is what I need to do to fix the boost problem?
  2. #2 Re: Having some issues with our recently purchased car. Please help.
    SE Level Member Mike Kopstain's Avatar
    Chicago, IL
    That's odd. It's as if the bypass is never seeing zero vacuum, even at wide open throttle or the spring that forces the bypass to return is broken and overcome by pressurized air. Have you checked to make sure that spring is indeed properly seated?
    Thinking about shopping with ZZP or the other guys? - Order with us instead and we'll give you a 5% off coupon code for your next order! Click here to learn how!
    Like us on Facebook!
  1. Just purchased an 02 GTP, few technical questions
    By toronado97 in forum General Tech Discussion
    Last Post: 02-15-2011, 01:05 AM
  2. Hello From Pittsburgh PA Just Purchased 2006 GXP
    By tmjz28 in forum Introductions/Noob Questions
    Last Post: 08-30-2010, 02:11 PM
  3. Whats with gaming recently?
    By DaytonaGTP in forum The Rant Forum
    Last Post: 08-17-2010, 11:10 AM
  4. Recently bought a 04 GT
    By Fubisin in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2009, 10:57 PM
  5. Finally decided and purchased a 3rd car.....
    By Iron Indian in forum Off Topic Discussion
    Last Post: 08-15-2008, 12:07 AM
