Thread: Having some issues with our recently purchased car. Please help.
Page 2 of 2 FirstFirst 12
Results 21 to 33 of 33
  1. #21 Re: Having some issues with our recently purchased car. Please help.
    SE Level Member Mike Kopstain's Avatar
    Chicago, IL
    Quote Originally Posted by mngtp View Post
    Im at work. I just had the service manager read the SES code (he use t work at a GM dealership). It came up with P404 and P1404 codes. He said the codes were saying its a bad EGR valve. Is this true? He also said as far as the boost issue, the blower is going out. What do you guys think? Could the lack of boost be affected by a bad egr valve? I just looked on craigslist and I called John's auto parts (a junk yard here in minnesota) and a used supercharger is $200-$300. The egr valve is $150. I really hate those kind of suprises. I would really like your guys' feedback. You guys seem to know these cars best. Thanks.
    Your supercharger isn't going out. If you had full boost and then all of the sudden had half boost, you knocked a vacuum line off somewhere or damaged the bypass valve by accident. I've never one of these superchargers fail and immediately output less boost. If anything, they wear over time and probably lose a nominal amount of output. A "failing" blower would be one that is making loud bearing noises and even that blower would still make full boost.
    Thinking about shopping with ZZP or the other guys? - Order with us instead and we'll give you a 5% off coupon code for your next order! Click here to learn how!
    Like us on Facebook!
  2. #22 Re: Having some issues with our recently purchased car. Please help.
    SE Level Member mngtp's Avatar
    Crystal, MN
    I know its probably a dumb question. But what is PB? I quickly cleaned the egr valve last night. The light went off after driving about 10 miles on the freeway while I was going to the store, but came back on on the way to work. Do you think I just need to clean the egr valve better?
  3. #23 Re: Having some issues with our recently purchased car. Please help.
    Houston
    Sounds like you will need to replace the EGR. PB Blaster is a penetrating catalyst that you spray on nuts that are rusted and froze up.
  4. #24 Re: Having some issues with our recently purchased car. Please help.
    Crystal, MN
    Ok. I had a guy at work watch the boost gauge while I reved the engine and worked with the valve. If I hold the arm (under the bbv, its the black dome thing like in the picture posted) up, nothing happens. But if I push it down so it is flat, it boosts full. I sprayed PB but it didnt make a difference. I reved the engine wthout touching it, the arm doesnt go all the way flat. I hope this makes sense. Any ideas? Ugh this is annoying. I bet its getting a little annoying for you guys too.
  5. #25 Re: Having some issues with our recently purchased car. Please help.
    Houston
    Makes sense...looks like a bad BBV too.
  6. #26 Re: Having some issues with our recently purchased car. Please help.
    Crystal, MN
    That about how my luck goes. Is it possible to replace the bbv? If so how hard is it? What would I need? And what would I need to do to replace the bbv? If I dont fix it, will it hurt anything else besides the performance of the car? This is my first car with a blower.
  7. #27 Re: Having some issues with our recently purchased car. Please help.
    Chicago, IL
    Is the electrical connector on the valve plugged in? Are you verifying that there is no vacuum leak? It's highly unlikely that the bypass valve would fail without any outside interference.
    If it indeed needs to be replaced it is a cheap and easy part to replace though.
  8. #28 Re: Having some issues with our recently purchased car. Please help.
    Crystal, MN
    I looked and didnt see any loose, broken, cracked, or separated vacume lines. I even sprayed carb cleaner all over like the tech at my job told me to do to detect any leaks and I found nothing. I will look to see about the electrical connection in the morning. I assume the connector is on the black dome part of the bbv. Correct?
  9. #29 Re: Having some issues with our recently purchased car. Please help.
    Houston
    I dont believe that the BBV has any electrical connections, it only has vacuum connections. Unless, Mike is talking about the BBV solenoid which is #7 on the vacuum diagram that I posted earlier in the thread. My car is at the muffler shop gettin some tips welded in, so I cant verify. But Im pretty positive the BBV itself has no electrical connections.
  10. #30 Re: Having some issues with our recently purchased car. Please help.
    Chicago, IL
    I missed this post... Does that arm go flat (horizontal) with the engine off? The more I think about it the less sense this makes as a vacuum leak would result in the valve staying closed which would result in constant boost. The arm connecting that piece is adjustable. If nothing else I would just adjust the boost bypass so that that little metal piece at the end of the rod stays flat under throttle (and with the engine off) and stays vertical when the engine is idling.
  11. #31 Re: Having some issues with our recently purchased car. Please help.
    Crystal, MN
    The arm is flat when the engine is off. But when the engine is running it is verticle. When the engine is reved the arm moves, but doesnt go all the way flat. How do I adjust the arm if that is what I need to do to fix the boost problem?
  12. #32 Re: Having some issues with our recently purchased car. Please help.
    Chicago, IL
    That's odd. It's as if the bypass is never seeing zero vacuum, even at wide open throttle or the spring that forces the bypass to return is broken and overcome by pressurized air. Have you checked to make sure that spring is indeed properly seated?
  13. #33 Re: Having some issues with our recently purchased car. Please help.
    Jul 2008
    sumter,south carolina
    did u check the rubber T fitting that goes into the lower intake mani under snout?
    02 GTP with mods 05 GP for DD
  1. Just purchased an 02 GTP, few technical questions
    By toronado97 in forum General Tech Discussion
    Last Post: 02-15-2011, 01:05 AM
  2. Hello From Pittsburgh PA Just Purchased 2006 GXP
    By tmjz28 in forum Introductions/Noob Questions
    Last Post: 08-30-2010, 02:11 PM
  3. Whats with gaming recently?
    By DaytonaGTP in forum The Rant Forum
    Last Post: 08-17-2010, 11:10 AM
  4. Recently bought a 04 GT
    By Fubisin in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2009, 10:57 PM
  5. Finally decided and purchased a 3rd car.....
    By Iron Indian in forum Off Topic Discussion
    Last Post: 08-15-2008, 12:07 AM
