anybody have a location for the cam sensor and crank sensor.
Cam sensor is on the front cover. below the water pump.
ok for give me but the front cover?
The timing cover. Front of the engine. What are you trying to do?
I am having an issue with my prand prix 3.8l sc motor. Loosing the tach and car wont run for anythihng.
You need to replace the crank sensor then more than likely, nothing to do with the cam sensor.
ok i will try it
Just a matter of pulling the Harmonic balancer
Remove both belts, remover passenger tire, remove crank bolt, install balancer puller, remover balancer, unbolt sensor.
ya got that part. thanks for the help.
