Thread: white smoke :'(
Results 1 to 5 of 5
  1. #1 white smoke :'(
    SE Level Member 97RS's Avatar
    Dec 2010
    miami fl
    in the pass 2 weeks the car's been taking a little long to start. today i start it to leave my cousins and it had trouble starting and after it did it was just pouring with white smoke all the way home... raditor is low on fluid now and no bubbles and the coolant isn't contaminated with oil. and the oil itself looks great no bubbles and no discoloration. i think its lower intake manifold gasket because now i don't remember if i used silicone around the coolant passage ways or not. and i did lower intake gasket like a little more then a month ago. im finding out tomorrow.
  2. #2 Re: white smoke :'(
    Dec 2010
    miami fl
    bump redid the lower intake manifold gasket with some right stuff around all the ports. tighten it all up and now it runs much better and no white smoke at all.
  3. #3 Re: white smoke :'(
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    good stuff
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  4. #4 Re: white smoke :'(
    Why did you put RTV around the ports of the gasket? This should not be necessary if the gasket is good. The typical coolant into intake on a supercharged motor is from a TB spacer, TB gasket or SC to LIM gasket. Did you find anything odd with those?
  5. #5 Re: white smoke :'(
    Dec 2010
    miami fl
    the motors in a camaro, i dont have any coolant going up the supercharger or into the tb. and it was the lower intake manifold gasket. and idk it looked ok but i guess the coolant somehow made its way around it. i replaced it with new gaskets and tighten the the bolts pretty tight. its worked so im happy.
  1. white smoke.
    By gtpinsc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-17-2011, 12:08 PM
  2. White smoke
    By dhaller in forum General Tech Discussion
    Last Post: 04-14-2010, 08:13 PM
  3. White smoke
    Last Post: 04-10-2010, 06:29 PM
  4. White smoke problem
    By SilverGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-05-2009, 10:24 AM
  5. SES light/White smoke
    By fudhimself in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-29-2009, 10:30 PM
