Quote Originally Posted by GTPguy2000 View Post
about 7 from the factory can be upped to 10 or 12 by the boost bypass mod, depending on your elevation,outside temp,internal temp,humidity ect. then theres the throttle body tricks wich can push it even higher , ive seen one hit 18 psi before blowing a head
this is so wrong it's not even funny. how can you mod the BBV to get more boost? answer: you can't. PLEASE do not tell people to play with the BBV. it is set at where it is for a reason. leave it alone.
what are you talking about with throttle body 'tricks' to get more boost? another invalid statement.
