Thread: how many psi of boost
Results 1 to 11 of 11
  1. #1 how many psi of boost
    brookfield connecicut
    just curious how many lbs of boost is the supercharged version of the 3800 series?
  2. #2 Re: how many psi of boost
    Houston
    stock...around 8psi
  3. #3 Re: how many psi of boost
    SE Level Member Agentlongwood's Avatar
    Nov 2009
    Orlando
    Can't remember where I saw it but I've seen it pegged around 6lbs give or take.
  4. #4 Re: how many psi of boost
    Waukesha, WI
    i saw 6 to 8
  5. #5 Re: how many psi of boost
    Duluth Minnesota
    Quote Originally Posted by redlinepontiac View Post
    i saw 6 to 8
    i have also seen 6-8 psi
  6. #6 Re: how many psi of boost
    Akron Ohio
    Ive hit 9 on a cold day
  7. #7 Re: how many psi of boost
    depends on the condition of the motor components and weather conditions. anywhere from 5-10 pounds of boost is possible.
  8. #8 Re: how many psi of boost
    Anywhere from .34 to .68 BAR
  9. #9 Re: how many psi of boost
    Dec 2010
    cny
    Quote Originally Posted by 2002gtx View Post
    about 7 from the factory can be upped to 10 or 12 by the boost bypass mod, depending on your elevation,outside temp,internal temp,humidity ect. then theres the throttle body tricks wich can push it even higher , ive seen one hit 18 psi before blowing a head
  10. #10 Re: how many psi of boost
    Quote Originally Posted by GTPguy2000 View Post
    this is so wrong it's not even funny. how can you mod the BBV to get more boost? answer: you can't. PLEASE do not tell people to play with the BBV. it is set at where it is for a reason. leave it alone.
    what are you talking about with throttle body 'tricks' to get more boost? another invalid statement.
  11. #11 Re: how many psi of boost
    So you're saying you can make a device which pushes a set amount of air per rotation at a set speed based on the ratio between the crank and the pulley on the snout push more air by changing things that dont affect this relationship nor the other relationships in the engine that determine how well the engine flows?
    Disregarding weather of course.
  1. boost?
    By Shang TI in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-04-2011, 09:07 PM
  2. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  3. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
  4. Low boost
    By jtemple54 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-29-2009, 03:21 PM
