Thread: Chugging
Results 1 to 9 of 9
  1. #1 Chugging
    SE Level Member mlasnoski's Avatar
    Jun 2010
    Marquette, Michigan 49855
    Anyone have any ideas why on occasion when turning into a a parking space my car wants to chug out and die. It never stalls, its just acts weird. Its usually when I'm turning right into a space. It just acts really weird. Could it be because it was cold outside and the car wasn't that warm? I only live 5 minutes from work. Its only done this a few times.
    2004 GTP CompG 104,400.
    Thanks for any knowledge
    Mike L.
  2. #2 Re: Chugging
    St. Louis
    Maybe a dirty IAC. With the low rpms and added load of turning into a parking space it may not be letting enough air in and almost stalling the motor.
  3. #3 Re: Chugging
    Jun 2010
    What is the IAC again. I am drawing a blank...
  4. #4 Re: Chugging
    its AWDsome JarenSTi's Avatar
    Hawaii
    idle air control. i googled it.
    2002 WS.6- exhaust, 42k miles
    2005 Subaru WRX
    2002 GT - sold
  5. #5 Re: Chugging
    It's an electronically controlled throttle bodied car...with over 104k...and over 7 years old...I'd bet 20 to 1 the throttle body needs to be cleaned. It tends to be a common issue with '04+ cars or most any GM car with a DBW TB.
    Just use some brake clean...that's what I did on my Cobalt around 50k...noticed a slight increase in MPG/idle quality
  6. #6 Re: Chugging
    04+ will be drive by wire and shouldn't have an IAC anymore.
  7. #7 Re: Chugging
    They don't...but the TB's get gunked up and cause idle and said "chugging" issue...just needs cleaninz
  8. #8 Re: Chugging
    Jun 2010
    Thanks! Question: my LIM gasket was replaced last May before I purchased the car, will garages clean the TB when they take it apart and put it back together or are they just focus on the problem at hand and won't look at anything as a kind gesture. My thought is, if it appears dirty and its something easy to clean, wouldn't you just do it for the customer. I'm wondering if they did it.
  9. #9 Re: Chugging
    It you have a flat headed screw driver...and a 10mm socket/ratchet...you can remove the TB and clean it by buying a 2 buck can of brake cleaner...and no...they won't do it...they'll probably tell you a slew of things are bad before they even attempt to just clean it.
  1. Humming Noise & Chugging
    By mlasnoski in forum Brakes/Suspension/Chassis
    Last Post: 02-23-2011, 11:26 AM
  2. chugging
    By davisg in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-15-2011, 06:01 AM
  3. Chugging,surging
    By dmahlikGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-17-2010, 11:36 AM
  4. Vehicle chugging
    By m1sterb0b in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-17-2009, 12:07 PM
  5. Stuttering... Chugging?!?
    By PonchoDvr4Lfe in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-22-2008, 06:53 PM
