Thread: NIC CAM or INTERCOOLER
Results 1 to 19 of 19
  1. #1 NIC CAM or INTERCOOLER
    GT Level Member lilrocket's Avatar
    landis,nc
    ok guys and gals im in a debate here ive looked at both cams and intercooling im torn between the two, i like the sound of the nic cam sounds pretty aggressive but the intercooler retains that sleeper look and sound so my question is does anyone run the nic if so wat the supporting mods zzps write up on it seem a little sketchy to me and wat the cheaper of the two routes. GO CAM OR INTERCOOLER
    98 DAYTONA 1110/1500: work in progress
    00 DAYTONA 216/2000: totaled but not forgotten parts car
    "Speed its my drug, the faster i go, the faster i want to go!"
  2. #2 Re: NIC CAM or INTERCOOLER
    goals for the car? how much money do you want to spend? if you want to drive the car daily you probably dont want a NIC.
  3. #3 Re: NIC CAM or INTERCOOLER
    landis,nc
    yes daily driver, goal mmm idk yet i wont it to be reliable but quick just checking into my options i work part time at a machine shop so intercooling i could probaly make myself but im just trying to see what everyone though worked better i see the full size intercooler guys are running like a 3.0 with supporting mods then i see the people run the nic cam are running 2.8 pulleys with supporting mods im wonting the best bang for the buck i ordered my headers and i have a set of 1.9 roller rockers off my 97 chiilin in the closet im just wondering so keep the ideas coming please
  4. #4 Re: NIC CAM or INTERCOOLER
    the reason people can run small pulleys on a NIC is because they need to. the NIC bleeds boost.
    an intercooler would be a better choice than a NIC, but if you want to go cammed there are better choices for that too.
  5. #5 Re: NIC CAM or INTERCOOLER
    landis,nc
    so best bang for the buck wat do you think go fullsize intercooler and the rockers or go cam the rockers i have are the roller yella terras and i have a set of ls6 springs with retainers i just liked the sound of the cam but i dont wont to mess up the drivability of my car either just wont to make it faster
  6. #6 Re: NIC CAM or INTERCOOLER
    An intercooler with bigger injectors and headers with a tiny ass pulley is whats up.
  7. #7 Re: NIC CAM or INTERCOOLER
    landis,nc
    mm nice thats kinda the road im going down right now anyway headers are on the way rocker i already have injectors wont be no problem, so wat would you think i could run pulley wise then with say headers intercooler injectors rockers
  8. #8 Re: NIC CAM or INTERCOOLER
    hell ya!!
    But pulley size is gonna depend on that tune brotha...
    but while your at it why not switch to E85
  9. #9 Re: NIC CAM or INTERCOOLER
    I was going to say E85...it just isn't practical in places.
  10. #10 Re: NIC CAM or INTERCOOLER
    Troy OH
    can you run 1.9 rockers with an aftermarket cam?
    perhaps a better question, is max height achieved with aftermarket or stock?
  11. #11 Re: NIC CAM or INTERCOOLER
    you can't go much higher than .600" without serious work.
    Not that lift means much really.
    The overall lobe shape matters quite a bit, but you can't really tell based on the limited cam specs they give you.
    But these motors are easy to mod because you can't change the bore/stroke, two head options, stock or ZZP's AL etc etc etc etc.
    Basically you can look at what others have made power wise with different cams and mods then decide for yourself what you want.
  12. #12 Re: NIC CAM or INTERCOOLER
    also depends how often and how you wanna drive it too
  13. #13 Re: NIC CAM or INTERCOOLER
    Donating Users Ibwrong's Avatar
    Oklahoma City
    I would have to agree with NIC.. Full Size Intercooler...Tune.. Crazy small pulley... E85... Injectors... I would throw in a XP cam. But thats just me.
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  14. #14 Re: NIC CAM or INTERCOOLER
    Feb 2009
    flintnasty MI
    Lift is not really your friend when playing around with mild bolt on stuff like this. Run stock rockers and enjoy the cheapness, reliability, and great performance they offer.
    Running a full sized intercooler with a NIC is fairly pointless overall... Intercoolers suck horsepower by causing a fairly significant intake restriction, and the gains from running an intercooler are not as clear as running one on XPZ cam or something.
    I am personally a big fan of the NIC... It has made great power in very very cheap setups for me in the past. Toss the cam in, put headers on, and make 300whp.
  15. #15 Re: NIC CAM or INTERCOOLER
    with the right person behind the tuner, yeah.
  16. #16 Re: NIC CAM or INTERCOOLER
    Feb 2009
    flintnasty MI
    Meh, it cant be that hard to put the right timing curve in and lower PE a bit. You just need to get a bit more fuel than stock to it, and remember that the narrowband is completely useless.
  17. #17 Re: NIC CAM or INTERCOOLER
    GT Level Member Wrongwayislost77's Avatar
    Arvada, Colorado
    NIC is a nice cam, but if you don't have access to a solid tune, an XP will be better. XP is probably better for IC'd setups too.
    Sig2
    30%, 5000k's, GMPP/Addco Sways, BMR Braces/Arms, FE3 Struts, WBS Springs, 12" w/ SS Lines & F-Bodies. Wiz, HVTB, HV3, CPlog, Shift Kit, ZZP 1.0, Alt/Volt Boost, Etc.
  18. #18 Re: NIC CAM or INTERCOOLER
    Feb 2009
    flintnasty MI
    Having tuned many of both, I disagree.
  19. #19 Re: NIC CAM or INTERCOOLER
    landis,nc
    thanks guys beeen a big help i just dont beleave i wont to ride around with a laptop tuning all the time to run the nic cam and as for wat im seeing the intercoolers seem more restrictive than they are good
  1. new intercooler??
    By sdenton8 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2010, 11:11 AM
  2. zzp intercooler vs wbody store intercooler ?
    By boostedgtp13 in forum Off Topic Discussion
    Last Post: 05-04-2010, 02:40 AM
  3. SS intercooler ?'s
    By QwikGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-25-2008, 12:11 AM
  4. which intercooler ???
    By DunriteDiesel in forum Off Topic Discussion
    Last Post: 06-15-2008, 10:40 PM
