Thread: Torque mount/strut help
Results 1 to 9 of 9
  1. #1 Torque mount/strut help
    SE Level Member ElAlacran2010's Avatar
    Dec 2010
    El Paso, Texas
    So i've destroyed yet another torque mount dogbone bushing. This would be my 3rd. I just wanna know if theres somebody who has changed out the bushing only, and how hard a task it is. Also any problems i would be coming across if i went this route instead of just buying a new dogbone. (which yes i know would probably be the simplest way of correcting this problem)
  2. #2 Re: Torque mount/strut help
    3rd.. odd. Have you checked the motor/trans mounts? Maybe they are allowing a lot of movement and killing the upper mount that you are having issues with.
    I think you can find the bushings only. ZZP W body store etc.
  3. #3 Re: Torque mount/strut help
    X2...I bet your lower mounts are trashed.
  4. #4 Re: Torque mount/strut help
    Dec 2010
    El Paso, Texas
    i've had the car for three years... but i've been overseas for some of that time. i do drive the car VERY aggresively. hopefully it isnt the lower mounts. i replaced the dogbone bushings today. i guess when i change my brake booster out this weekend i'll find out about the lower mounts....
  5. #5 Re: Torque mount/strut help
    '02 GTP oneil.GTP's Avatar
    Oct 2008
    Peoria, IL
    lower mounts are gravy to change. take an hour with a few smoke breaks.
  6. #6 Re: Torque mount/strut help
    And a few drink breaks...it is always nice to have someone help just incase the mounts don't line up.
  7. #7 Re: Torque mount/strut help
    Oct 2008
    Calgary, Alberta
    Replace the lower engine mount with a solid rubber alternative. I destroyed a cheap hydraulic one in less than 1 year (might be leaking from the front main seal, less than 1 l per 3000 km).
    I ended up using a energy suspension polyurethane mustang transmission mount. I drilled out the cradle, and bracket on the car for fitment, and used washers and large nuts as spacers underneath.
  8. #8 Re: Torque mount/strut help
    ZZP makes a poly engine mount AND a poly transmission mount...
    Engine is 150 bucks and the trans is 80...I've got both now.
  9. #9 Re: Torque mount/strut help
    Dec 2010
    El Paso, Texas
    too many drink breaks, usually means the work goes unfinished! lol. but thanks alot for the help.
  1. Strut mount keeps failing
    By Silver GTP in forum Brakes/Suspension/Chassis
    Last Post: 12-13-2010, 12:37 AM
  2. Strut Mount rattle
    By Lvgrandprix2003 in forum Brakes/Suspension/Chassis
    Last Post: 03-10-2010, 09:23 AM
  3. Need help with with rear strut mount??
    By 99GTP99 in forum General Tech Discussion
    Last Post: 02-18-2010, 08:27 AM
  4. Strut Mount Caps?
    Last Post: 01-09-2010, 11:50 PM
