Thread: Can someone give me MAF #'s?
Results 1 to 1 of 1
  1. #1 Can someone give me MAF #'s?
    SE Level Member T0pwater's Avatar
    SW Michigan
    I'm looking for some representative MAF readings at different RPM's. Also, does anyone have the MAF frequency (Hz) to CFM's or lb/min air flow rate conversion formula?
    This is what I'm looking for: at x RPM, MAF is around y Hz (for several RPM's). And, CFM (or lb/min) = .... (function of freq).
    My goal is to do some flow calculations to find theoretical pressure drop per foot of intake tubing to quantify what people have been saying on this forum and others about tradeoffs between intake types.
    Edit: I have the LQ4 MAF table from ZZP's website, so if someone posts Hz-RPM numbers who was running an LQ4 MAF, I don't need the formula for converting to CFM. Otherwise, with stock MAF, I need formula + numbers.
  1. should i give up
    By GTPgurl in forum General Tech Discussion
    Last Post: 07-29-2010, 12:28 PM
  2. Ok, i give, what is this?
    By TowerLadder43 in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-30-2010, 02:51 AM
  3. Give this a try...
    By kjclawson in forum Off Topic Discussion
    Last Post: 03-05-2010, 02:31 PM
  4. Will you give this to my Daddy?
    By TMC in forum The Rant Forum
    Last Post: 05-09-2009, 09:55 PM
  5. This car will definitely give you wood!
    By Warhellride in forum Off Topic Discussion
    Last Post: 05-09-2008, 06:06 PM
