Thread: Trouble Code P2043 Fixed/2005 GTP
Results 1 to 6 of 6
  1. #1 Trouble Code P2043 Fixed/2005 GTP
    SE Level Member TheRoadWarrior's Avatar
    Fort Polk
    I had posted about a month ago about how I had trouble code 2043 that said "Solenoid A malfunction." When I did research on the code it only came up with results from turbocharged vehicles, ranging from dodge neon SRT-4 to the turbo diesel trucks. When I asked people on this forum I recieved general info, nothing precisely pinpointing the problem. I solved it and saved a lot of money doing it myself, so I wanted to share with everyone to save someone else some money.
    When the CEL first came on the car felt very sluggish acceleration during all driving conditions. This was because the actuator for the boost bypass valve was damaged and venting most of the boost from the supercharger into the atmosphere, so the car felt like it lost a lot of horsepower.
    I had a hard time finding the part. General parts stores like autozone don't sell anything remotely close to a wastegate solenoid, or boost bypass valve or the like. I went to the dealer and they tried to sham me into paying for a diagnostic fee to tell me what was wrong. I told the guy the trouble code and he insisted that I didn't know what I was talking about and that I HAD TO PAY TO GET MY COMPUTER SCANNED, which was about 65$. I told him to fornicate with himself and went elsewhere. The parts department at the dealer didn't even help me and said that they could not find any related part from my description and that I would have to bring in the part so they could find out more information or check the part number.
    I looked under the hood at what and where this part was, I found it easy enough, it was the only thing that could possibly be the part since its the only thing attached to the supercharger that isn't emmisions or throttle related.
    I noticed that no matter if the car were running or not, the valve was very loose and did not seem to be holding vacum, it was just flopping back and forth with little effort. I checked the vacum lines and they were tight and leak free, so it must be the actual valve itself.
    I went to the dealer with the valve and they found it immediately and said it was sold as "Actuator Kit" part #89018120 and was 252$. There was the schematic drawings with the part easily recognizable, so at least I know exactly what the part is and where and how much it is.
    I then went to the local "pick and pull" junkyard and started the hunt for a 3.8 supercharged GM vehicle. I found only one that was not picked clean. It was a late 90's bonneville, but the valve and solenoid looked identical so I figured I would take it and at least try it out. I checked the part numbers on my broken one and the new one and they didn't match, but I decided that since they look identical and bolt up the same that I would still try.
    Success! I got the whole "Actuator Kit" from the junkyard for 20$ and it fixed my CEL, performance is back to normal. Now the valve is functioning properly and holds vacum, you cannot easily move the valve back and forth anymore, and when the vehicle is idling it is in the open position and steadily closes as the throttle is depressed.
    I saved 252$, plus diagnostic fees 65$, labor from the dealer 70-140$ so that bill would have been easily over 500$! I'm treating myself to something nice for my little bit of mechanical knowledge and common sense to not let myself be raped by dealers!
    I'd post pics but for some reason it won't let me and just says "Upload failed."
  2. #2 Re: Trouble Code P2043 Fixed/2005 GTP
    Portland Oregon
    Good job on hunting down the new part. Most people that aren't that mechanically inclined would have had it done at the dealer. If your used one fails in the future you can get them brand new for 40 bucks from vendors such as Zzperformance.com
    ZZ Performance
  3. #3 Re: Trouble Code P2043 Fixed/2005 GTP
    Fort Polk
    Quote Originally Posted by OH4CompG View Post
    ZZ Performance
    Son of a *****, I looked all over the internet for a photo of the stupid part I needed and it was right there on ZZ performance! The GM dealer didn't even have a photo, just the ambigous schematic diagrams.
    Thanks!
  4. #4 Re: Trouble Code P2043 Fixed/2005 GTP
    Feb 2009
    Colton , California
    anyway i can see a picture of the engine and what was broken ?
  5. #5 Re: Trouble Code P2043 Fixed/2005 GTP
    SE Level Member glhtomni's Avatar
    iowa
    im new to these 3.8 cars but i am a boost freak. i have owned a ton of chrysler 2.2 and 2.5 turbos and the wastegate canister can cause similiar issues, never really had a wastegate solenoid go bad, then again i dont use them, i replace them with a boost controller to over ride the factory boost setting. but the springs in the stock waste gate can get worn out and you lose boost pressure some or the actuater rod comes completely off and u have no boost. also atleast on the turbos, if the vac line comes off the wastegate, there is nothing controlling the boost level and u can spike way past the point of fuel that the injecters can deliver and BOOM!!! u have a former piston as a new ash tray lol
  6. #6 Re: Trouble Code P2043 Fixed/2005 GTP
    Aug 2012
    United States
    WOW thank God for you. I have been getting this error code for about a month now. I want to fix the problem but my car is running fine. Only issue is an occasional scare of over heating. My mechanic says its only a dealer part and not to worry about it because the car is driving fine. Well Im taking a camping trip in a few weeks and did not want to drive my car up a mountain pulling my jet ski and BOOM broken down vehicle. Thank you so much for posting this...many blessings. I can't stand dealers and was dreading paying $300 for a part. Cudos!!!!
  1. Trouble code P0455
    By powerranger262 in forum General Tech Discussion
    Last Post: 09-23-2014, 03:09 PM
  2. p1811 code fixed
    By bigtee in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-11-2010, 04:18 PM
  3. Trouble Code Help
    By TheRoadWarrior in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-15-2010, 07:26 PM
  4. P0442 trouble code?
    By hunter_alexander in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-05-2008, 10:33 AM
  5. General OBD-2 Trouble Code (DTC) list
    By Sinister Performance in forum PCM Tuning
    Last Post: 02-22-2008, 02:15 AM
