Thread: 136,000 miles, losing coolant, intake manifold gaskets shot from DEX COOL ???????
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21 Re: 136,000 miles, losing coolant, intake manifold gaskets shot from DEX COOL ???????
    Donating Users mystic231's Avatar
    Michigan
    What the hell made that low coolant light come on then?
    Sensor is bad. I've changed two (on the same car) in four years. The sensor is a Delphi part made in Mexico (go figure). The sensor is on the right radiator tank about half way down.
    '98 Bright Red GT 278,000 miles and counting...
    '02 Galaxy Silver GTP GMPP Suspension, F Body front brakes, TDC FWI intake, Ported M90, Intake, and Throttlebody, Overkill PCM
    '02 Bright Red GT
  2. #22 Re: 136,000 miles, losing coolant, intake manifold gaskets shot from DEX COOL ???????
    cleaning it might help.
  3. #23 Re: 136,000 miles, losing coolant, intake manifold gaskets shot from DEX COOL ???????
    Nov 2008
    Hamburg, IL
    Yea I aint sure whats going on yet... I check the antifreeze level every oil change, along with all the other fluids.... When the light came on the first and only time, I was sitting in it outside my garage getting ready to leave after letting it warm up to operating temp on a cold ass day.... I noticed the temp gauge was slightly above normal too when the light came on. I revved the engine to 2000 rpms and the temp gauge immediately went back down to where it normally runs... I assumed then it actually was low on coolant thus revving the engine sped the water pump circulating the coolant better and covering the sensor for the temp and coolant level. Who knows, maybe its time for a thermostat.
  4. #24 Re: 136,000 miles, losing coolant, intake manifold gaskets shot from DEX COOL ???????
    From your story.. uh...did you check the coolant level yet?
  5. #25 Re: 136,000 miles, losing coolant, intake manifold gaskets shot from DEX COOL ???????
    Nov 2008
    Hamburg, IL
    I check it every oil change, I already checked the radiator, it was full, coolant bottle was the only thing low
  6. #26 Re: 136,000 miles, losing coolant, intake manifold gaskets shot from DEX COOL ???????
    Hmmm could have pulled some into the rad. Light still on?
  7. #27 Re: 136,000 miles, losing coolant, intake manifold gaskets shot from DEX COOL ???????
    Nov 2008
    Hamburg, IL
    No sir. The light was only on for 10 seconds , then went off after revving it to 2000 rpms as I was talking about on the previous post..... This was all before I filled the tank
  1. Losing Coolant from Overflow tank
    By Suaveat69 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2010, 10:00 PM
  2. Exhaust Manifold Gaskets
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-05-2010, 12:22 AM
  3. Intake gaskets
    By HumanWeapon in forum General Tech Discussion
    Last Post: 11-06-2009, 02:52 PM
  4. intake gaskets
    By dpmeeks in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-09-2009, 01:24 PM
  5. Intake manifold
    By joesforspeed in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2008, 12:15 PM
