Thread: Coolant bleeding
Results 1 to 5 of 5
  1. #1 Coolant bleeding
    PCMO
    Is there a "enviro friendly" way to bleed the coolant on the 3800? Bleeding mine drains right on the exhaust man. and on to the ground. I thought about rigging a line up to bleed back to the overflow tank. Any ideas?
  2. #2 Re: Coolant bleeding
    The petcock in the bottom of the radiator on the drivers side.
  3. #3 Re: Coolant bleeding
    Donating Users kfish's Avatar
    Ohio
    Hes talking about bleeding it not draining it lol.
    I just wrap a few rags around the tstat housing and crack the bleeder screw. the rag soaks up the coolant as it spews out. Once you have a steady stream coming out your good to go.
    <nawarkk> listen maybe I like being gay
    <rynoman03> my dildo i have is old
    <01GTP> my penis is chrome plated
  4. #4 Re: Coolant bleeding
    Florida
    I do the same thing as kfish.
    Just get a shop rag, or an old towel, and it'll soak up all the coolant.
  5. #5 Re: Coolant bleeding
    St. Louis
    I just crack the bleeder open and let it drip. It'll burn off the mani anyway, and what little bit does reach the ground helps control the stray cat population in my area. Keeps the little f'ers off my cars and out of my garages. Screw the EPA, lol...
  1. Brake Bleeding Procedure
    By SJAndrew in forum Brakes/Suspension/Chassis
    Last Post: 08-12-2010, 06:20 PM
  2. low coolant light...but not so much low coolant..?..
    By 1lilcountrygrl in forum General Tech Discussion
    Last Post: 08-08-2010, 12:29 PM
  3. Trans is bleeding!
    By Toofastgs in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-27-2010, 09:58 PM
  4. Coolant
    By kaiser0427 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-22-2009, 08:03 AM
  5. 1992 Grand AM Brake Bleeding help
    By rmacinc in forum Brakes/Suspension/Chassis
    Last Post: 01-23-2009, 09:51 AM
