Thread: 1999 gtp 3.4 pulley supercharger problem
Results 1 to 20 of 22
  1. #1 1999 gtp 3.4 pulley supercharger problem
    new brunswick
    hey i recently chaged my motor i have but a 3.4 inch pulley with u bend remove ,cat remove,cold air intake, and 2.5 inch exhaust and colder plugs and 180 t stat, and my problem is that went i start it its hard to start and no power boost wont go up and cuts out wen i take my supercharge belt off car runs like new but with no power of cours cusse no supercharge NEED HELP !!
  2. #2 Re: 1999 gtp 3.4 pulley supercharger problem
    GTX Level Member tayl5645's Avatar
    Jul 2010
    Michigan
    Sound liek your knocking like crazy... Mods dont support that 3.4
    2005 GTP Grey
    Custom built Open cone intake, 15% tints all the way around, 7" touchscreen DVD player
  3. #3 Re: 1999 gtp 3.4 pulley supercharger problem
    Jul 2010
    Michigan
    http://www.grandprixforums.net/safel...car-17482.html
    This link is going to help you a ton.. read it please
    2005 GTP Grey
  4. #4 Re: 1999 gtp 3.4 pulley supercharger problem
    ^^That.
  5. #5 Re: 1999 gtp 3.4 pulley supercharger problem
    new brunswick
    yah i have put back my 3.8 inch stockl pulley and no change
  6. #6 Re: 1999 gtp 3.4 pulley supercharger problem
    GTP Level Member biggt's Avatar
    Jul 2010
    Montreal
    if your running a 3.8 now and nothing changed
    maybe you have a chipped piston?
    02 SilverMist GT L67 SWAPPED
    Quote Originally Posted by RedDawnGXP View Post
    Yeah plus he has a lot of weight reduction with the clear corner lights.
  7. #7 Re: 1999 gtp 3.4 pulley supercharger problem
    ignition issues?
  8. #8 Re: 1999 gtp 3.4 pulley supercharger problem
    Check the plugs
  9. #9 Re: 1999 gtp 3.4 pulley supercharger problem
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    Are you reading full boost on your gauge?
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  10. #10 Re: 1999 gtp 3.4 pulley supercharger problem
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    Id do the compression test first off and go from there.
  11. #11 Re: 1999 gtp 3.4 pulley supercharger problem
    new brunswick
    no im not reading full boost som time 2 line thats it and its a motor with 90.000 km and the car runs way better without the supercharge belt it would be a chip piston it would run like **** all the time.
  12. #12 Re: 1999 gtp 3.4 pulley supercharger problem
    Check for a vacuum leak? Checked the plugs yet? Have any SES lights?
  13. #13 Re: 1999 gtp 3.4 pulley supercharger problem
    SE Level Member Powertrike's Avatar
    Jul 2010
    MN, US
    this
  14. #14 Re: 1999 gtp 3.4 pulley supercharger problem
    Jul 2008
    sumter,south carolina
    chipped piston doesnt necessarily mean ur gonna run like ****... i ran on 2 chipped pistons for almost a year with no signs of it being chipped other than broken spark plugs. check the rubber T under the snout.
    02 GTP with mods 05 GP for DD
  15. #15 Re: 1999 gtp 3.4 pulley supercharger problem
    new brunswick
    whats the rubber t under the snout and can you tell me if you know whats the sensor behind the motor betwen the motor and the trans its in and hard place to get it out ,,mine was broken and mabey thats my problem
  16. #16 Re: 1999 gtp 3.4 pulley supercharger problem
    Dec 2008
    Alabama
    Can't you have low boost with a bad, is it, boost actuator?
  17. #17 Re: 1999 gtp 3.4 pulley supercharger problem
    Bastard Reptile's Avatar
    Kansas City, MO
    Quote Originally Posted by gtpzzp View Post
    That is the rear knock sensor. And yeah, it can be a bear to get out.
    That won't be the reason it's not reading full boost though, Either you have a bad vac leak on the lines, or the boost valve isn't closing, which gives you about 4-6 lbs of boost at most.
    Some people run with only one knock sensor working for a while without even noticing it, it's important to have both working though.
  18. #18 Re: 1999 gtp 3.4 pulley supercharger problem
    GTX Level Member real diehl's Avatar
    Salina, KS
    Holy run on sentences OP
    signature removed for inappropriate content.
    -bio
  19. #19 Re: 1999 gtp 3.4 pulley supercharger problem
    SE Level Member Lacboi's Avatar
    Jun 2010
    Atlanta
    sounds like the bbv solenoid. i just unpluged mine and boost came back
  20. #20 Re: 1999 gtp 3.4 pulley supercharger problem
    You did get a new one right?
  1. 1999 grand prix gt idle problem..
    By 1999gpgt in forum General Tech Discussion
    Last Post: 01-24-2011, 01:11 PM
  2. 1999 Grand Prix 3.1L Odd Problem.
    By Xware in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-22-2010, 06:22 PM
  3. 1999 blower problem +++
    By H2o53 in forum General Tech Discussion
    Last Post: 05-04-2009, 12:01 AM
  4. 1999 Grand Prix 3.1L steering problem
    By Big Tom in forum Brakes/Suspension/Chassis
    Last Post: 11-14-2008, 11:05 AM
