Thread: Pressing the pulley off
Results 1 to 4 of 4
  1. #1 Pressing the pulley off
    Fla.
    Is it safe to press the pulley off, by driving the shaft and inner bearing out on a press without cracking the snout housing??I need to rebuild the snout,bearings,and seal. I might bring it by my local motorcycle shop, and watch him do it. Thanks
  2. #2 Re: Pressing the pulley off
    SE Level Member fst4dr's Avatar
    Calgary
    I pulled the whole snout of then braced under either side of the pulley put a bolt in snout and the pressed with a 20 ton press and it came off like butter! no harm to snout either
  3. #3 Re: Pressing the pulley off
    Fla.
    Quote Originally Posted by fst4dr View Post
    Thanks, I'll try it that way to be safe.
  4. #4 Re: Pressing the pulley off
    '02 GTP oneil.GTP's Avatar
    Oct 2008
    Peoria, IL
    or you could rent one..
