Thread: so I kind of scanned my car.
Results 1 to 3 of 3
  1. #1 so I kind of scanned my car.
    GTX Level Member Juanmiguel's Avatar
    Mexico
    well I finally got the bluetooth obdII thing here. My DHP powertuner is in the mail and I should be able to get a decent scan once I get that one, but I did one with the one I've got for the time being.
    Bad news is that KR is not working and the second fuel trim isn't either.
    One of the things that I noticed is that I'm running as much as 13.5 timing at WOT and it drops to 15-16 at the top of 2nd gear. Which leads me to believe that I may have some KR at this point.
    Another thing that I noticed is that my mechanical "sunpro" boost gauge would peak at around 12 psi with my current setup, but the scanner is only reporting a peak 7.5 psi which one should I trust? how much PSI should I be getting at peak with my setup?
    Also I read and was advised that the fuel trims should be around 0 and -2 or -3 i think. But I'm not sure if these are the trims that I should be comparing. They do lock at 0 in PE, but the variance is much greater that it's supposed to be.
    This is the first time I scan and try to analyze the data. So any input will be appreciated.
  2. #2 Re: so I kind of scanned my car.
    Mexico
    .zip file attachment fails...
    her's a rapidshare link:
    http://rapidshare.com/files/44524645...eTrackLog2.xls
  3. #3 Re: so I kind of scanned my car.
    Jersey
    cant see file. How are you scanning? you really can't get a good scan by 3-1 downshifting from rolls best way to scan is from a dead stop, 0-100 (redlining 1-2 shift at wot without spinning) unless you see more than 4* of knock, blips happen, some could be false. Get rid of those tr6's, 104 cheapo crap autolites is what these motors like. Fuel trims are all over the place, as long as they lock in as close to 0 as possible. You could have a vacuume leak.
    16' wrx sti- stock
  1. Get the car scanned?
    By boosted97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-07-2010, 11:59 PM
  2. Scanned my car today.
    By JoshsGTP in forum General Tech Discussion
    Last Post: 09-15-2010, 11:59 AM
  3. What kind of oil?
    By chitownballer8908 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-13-2009, 12:57 PM
  4. Want to get my car scanned. Where? How?
    By 04CompG in forum General Tech Discussion
    Last Post: 03-20-2008, 10:17 AM
  5. what kind of oil?
    By s1795so2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-16-2008, 07:37 PM
