Thread: SC oil leak?
Results 1 to 10 of 10
  1. #1 SC oil leak?
    GTX Level Member Juanmiguel's Avatar
    Mexico
    Sometimes I've noticed that the vacuum lines underneath the SC snout get greasy, with what appears to be oil I normally clean them and stay like that for a while, but I think it's getting worse now.
    It's been less than a month since I installed the 3.25 pulley and it looks already dirty from the inside.
    Today I also noticed the fuse box was stained with oily substance as well as the vacuum lines underneath the snout.
    The oil has no color to it either.
    I'm thinking this is most likely SC oil. Is there a way to check the level? If it is SC oil where can it be leaking from? the breather and where it joins with the housing?
  2. #2 Re: SC oil leak?
    on the snout, there is a allen head bolt, take it out and check the level
  3. #3 Re: SC oil leak?
    Mexico
    yeah, but does the bolt have some kind of level indicator or how should i know if it needs more?
  4. #4 Re: SC oil leak?
    the level should be at or right around the botttom of the threads.
  5. #5 Re: SC oil leak?
    Mexico
    great thanks, i'll take a look.
  6. #6 Re: SC oil leak?
    That probably isn't from the blower itself sealing...it is the snout seal probably bad considering it is just hanging out behind the pulley. Is there a residue on your hood as well? If so...its a snout seal...
  7. #7 Re: SC oil leak?
    Donating Users
    South Deerfield, MA
    I was thinking snout seal too reading your description. They are easy to change if you can pull your mps and pulley off.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  8. #8 Re: SC oil leak?
    Mexico
    not sure about the hood, I'll have to check. Do I have to take out the MPS hub in order to change the seal?
  9. #9 Re: SC oil leak?
    Bastard Reptile's Avatar
    Kansas City, MO
    Yeah, you will. The seal is driven into the end of the snout.
  10. #10 Re: SC oil leak?
    Mexico
    Crap, now I regret having only rented the pulley puller... I'll add more SC oil and buy a pulley puller with the backing plate later on.
    Thanks!
  1. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
  2. Oil Leak
    By Wicked13 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2010, 08:59 AM
  3. oil leak on 3.4 dohc. Not that oil leak.
    By 67GTO in forum General Tech Discussion
    Last Post: 06-14-2010, 11:52 AM
  4. vac leak i think?
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 05-26-2010, 07:55 AM
  5. oil leak
    By whitegtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-25-2008, 03:48 AM
