Thread: looking to change tranny fluid
Results 1 to 15 of 15
  1. #1 looking to change tranny fluid
    GT Level Member Spartanzz's Avatar
    Dec 2010
    Lawrenceville, GA
    So how much of the fluid does it hold? Which fluid does everyone recomend? Also there is a leak we believe to be the seals to the axel is this common?
  2. #2 Re: looking to change tranny fluid
    Donating Users
    South Deerfield, MA
    A little over 7 qts. iirc with a pan drop and filter change. Axle seals can fail, but it is not something I heard of happening frequently.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  3. #3 Re: looking to change tranny fluid
    Dec 2010
    Lawrenceville, GA
    Ok thx for the info man!
  4. #4 Re: looking to change tranny fluid
    tranny holds 12-13 quarts TOTAL
    but on a pan and filter drop, you lose 7ish quarts.
    I'd buy 8 quarts just to make sure.
  5. #5 Re: looking to change tranny fluid
    Vancouver, WA
    Mine took 8 quarts. Any major brand Dex VI
  6. #6 Re: looking to change tranny fluid
    Dec 2010
    Lawrenceville, GA
    yeha i herd Dex VI so was planning to get that just wanted to see how much its gunna cost me looks like a decent amount lol. yeah we saw a leak on the car and thought it was coolent but then soon found out it felt different than the coolent so we checked it with the tranny fluid and thought it would be the axel seals so figured id change the fluid when i change the seal might as well.
  7. #7 Re: looking to change tranny fluid
    Vancouver, WA
    I believe it cost me about $50 for the fluid and like $10 for the filter.
  8. #8 Re: looking to change tranny fluid
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    It's probobly assumed, but make sure you check your trans fluid after the first drive, and then again maybe one week later.
  9. #9 Re: looking to change tranny fluid
    If yours is factory filled with dex VI, thats what you put in.
    If not, put synthetic dex III in there.
    The fluids are different.
  10. #10 Re: looking to change tranny fluid
    GT Level Member djrepoman's Avatar
    columbus ohio (polaris)
    Dex 6 will work just fine, as its been designed to be backwards compatible. Ive been running it in both of my Gps for 2 yrs now and over 65k miles with 0 issues
    2000 GT ,E85 powered, and still slow
    98 GTP Stock
  11. #11 Re: looking to change tranny fluid
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    yeah just use dex6 the extra cost of synthetic isnt worth it
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  12. #12 Re: looking to change tranny fluid
    Quote Originally Posted by djrepoman View Post
    Dave from TEP recommends Dex III over Dex VI if it was factory filled with dex VI for reasons of viscosity.
    Look up the specs on mobil's website.
    Quote Originally Posted by Rather B Blown View Post
    Dex VI costs just as much as synthetic Dex III here.
  13. #13 Re: looking to change tranny fluid
    Vancouver, WA
    When I said Dex VI I assumed synthetic was a given. I don't see why you wouldn't use the best if you really do care about your car.
    Matt, if you want to start getting all specific on what Dave recommends its CAT oil not Dex III. I stay say Dex VI full syn.
  14. #14 Re: looking to change tranny fluid
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    ive read of numerous people having shifting issues after putting the new dex 6 in our trannys. i also just read in this thread a couple people have had no issues with it. i wouldnt chance it. (in fact, i didnt)
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  15. #15 Re: looking to change tranny fluid
    Vancouver, WA
    I've been running it for a couple months now, its great. I havent heard anyone complain about it that is actually using it, just the naysayers that don't use it.
  1. Dex VI Fluid Change
    By The Guz in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-01-2010, 04:55 PM
  2. Tranny fluid and filter change
    By chevyy1212 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-16-2010, 03:49 PM
  3. Supercharger fluid change 01 gtp
    By brownb66 in forum General Tech Discussion
    Last Post: 11-19-2009, 07:41 AM
  4. tranny fluid change ?
    By NEONNIGHT34609 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-19-2008, 09:48 AM
  5. Transmission fluid change
    By 2000GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-06-2008, 03:42 PM
