Thread: Cam and spring shootout!!
Results 1 to 14 of 14
  1. #1 Cam and spring shootout!!
    TDCRacing
    Guest
    ok where do i start....
    Xp cam
    90# springs
    105#springs
    specs...
    212°/224° at .050"
    Intake Lift .325" (.520" lift at 1.6:1 rocker ratio)
    Exhaust Lift .335" (.536" lift at 1.6:1 rocker ratio)
    116 Lobe Separation
    I need a cam ...you tell me what combo is better using the above parts and why..and i will be replacing the tensioner and i don't care about it wearing out ''quicker''
  2. #2 Re: Cam and spring shootout!!
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    Why not go with a double roller?
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  3. #3 Re: Cam and spring shootout!!
    i have a rockered car and kept my double roller after i got rid of my cammed setup just for the pure fact that ill never have to open the front cover again.
    with the xp id do 105# springs, but you can use 90# if you want.
  4. #4 Re: Cam and spring shootout!!
    TDCRacing
    Guest
    fill me in on the double rollers...all they were on the 5.0's were ''double the size of the stock timing chain'' but why would you never have to open the front cover again?
  5. #5 Re: Cam and spring shootout!!
    New Salem, ND
    It is one chain but is built like two chains side by side. So instead of one set of teeth on a gear there are two. Does that make sense. ZZP does not have a good pic on their site. But there is a catch to running a double roller. To do it safely it is has been discovered that you need to machine the crank gear. Here I will find the thread on this forum that discusses it all.
  6. #6 Re: Cam and spring shootout!!
    New Salem, ND
    http://www.grandprixforums.net/f18/t...ains-2351.html
    Reptile could probably explain it better.
  7. #7 Re: Cam and spring shootout!!
    TDCRacing
    Guest
    Ok makes sense...im sticking with the stock timing chain
  8. #8 Re: Cam and spring shootout!!
    you delete the tensioner with a double roller. i milled down my oil pump cover 20 thousandths and ive been fine since. a stock timing chain and dampener are fine, but they just wear out a little quicker with a cammed setup.
  9. #9 Re: Cam and spring shootout!!
    New Salem, ND
    I would also get the bevel machined on the crank gear.
  10. #10 Re: Cam and spring shootout!!
    Bastard Reptile's Avatar
    Kansas City, MO
    I thought so too....but mine still rubbed, and you saw the end result of that fiasco.
    machining the pump cover and then the crank gear should make it fairly trouble free.
  11. #11 Re: Cam and spring shootout!!
    Wichita, KS
    I'm now VERY comfortable with my machined crank gear on my double roller. Before, I only had a machined oil pump cover, and it was damn close to rubbing with it being machined.
    The bevel added to the crank gear made me worry free now about running it.
    I find it funny that Zooomer/ZZP said on CGP that running a machine oil pump cover would cause more problems than running two front cover gaskets...they recommended only running two front cover gaskets...now they sell machined oil pump covers...how long before they start selling correctly machined double roller timing chain sets with the modified crank gear? But wait...there is no problem with the double rollers. Only a select few have this issue.
    ~F~
  12. #12 Re: Cam and spring shootout!!
    New Salem, ND
    Quote Originally Posted by GR8racingfool View Post
    ~F~
    I saw that also and just thought whatever I guess. That is the result of letting your customers be the ginnie pigs.
  13. #13 Re: Cam and spring shootout!!
    TDCRacing
    Guest
    heh...
  14. #14 Re: Cam and spring shootout!!
    Feb 2008
    my question is: How much quicker do the 90# springs wear out the tensioner than the 105#, and how much quicker does a cammed setup on 105's wear one out than stock? I'm at 120k and still on my stock timing chain and dampener with stock cam.
  1. Spring rates
    By bula81069 in forum Brakes/Suspension/Chassis
    Last Post: 04-10-2011, 10:21 AM
  2. Indiana GPC Summer Shootout
    By suprchrgd in forum Shows and Events
    Last Post: 06-24-2008, 06:11 PM
  3. Big OQCGP Spring BBQ.
    By Meemperor in forum Shows and Events
    Last Post: 06-10-2008, 09:47 PM
  4. I love the spring
    By mlambert in forum Visual/Body Modifications
    Last Post: 05-07-2008, 11:38 AM
  5. Valve Spring replacement...
    By Iron Indian in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-01-2008, 07:30 PM
