Thread: reusable engine parts
Results 1 to 7 of 7
  1. #1 reusable engine parts
    Central Florida
    i know that the cam, crank, main bolts all need to be replaced along with gaskets on a rebuild but what all is reusable? like timing chain, lifters, connecting rod bolts, flexplate bolts and whatever else anyone can think of.
    im in the middle of a budget rebuild and kinda need to get it back road worthy sooner and cheaper than later and more expensive.
    thanks in advance!
    1998 Pontiac GTP - rebuilding
    1991 Mazda MX6 GT - DD
  2. #2 Re: reusable engine parts
    you can re-use a cam and crank, just get them machined.
  3. #3 Re: reusable engine parts
    things that automatically get changed.
    Bearings (after checking them)
    Bolts (every bolt is TTY)
    Timing chain (it's cheap, don't put a semi stretched one back in)
    Something to keep in mind though is usually you can get a used motor cheaper than you can rebuild. And if you are turboing.. look into the 04+ GP NA motor. I've seem them low..like $300 for a motor with 50K
  4. #4 Re: reusable engine parts
    Central Florida
    i couldn't really find anything used around me at the time and already had the machine work done.
    so im going to need all new bolts. it there a way to clean the lifters?
  5. #5 Re: reusable engine parts
    Florida
    I cleaned mine out by soaking them in parts cleaner, then letting them dry off, and then soaking them in oil before I reinstalled.
  6. #6 Re: reusable engine parts
    St. Louis
    Quote Originally Posted by turbo6 View Post
    Did you have the block line bored as well? I've heard that this is a must when rebuilding one of these motors.
  7. #7 Re: reusable engine parts
    Central Florida
    not that i remembered but everything was spec. out and measured, and the guy has been doing it for years on end.
  1. l32 aluminum blower gasket reusable?
    By 97RS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2011, 01:39 AM
