Thread: computer reset itself???
Results 1 to 8 of 8
  1. #1 computer reset itself???
    SE Level Member GTPgurl's Avatar
    Jul 2010
    syracuse, ny
    so i wen out to start my car yesterday and it wouldnt start ,then it started and imidiately stopped, then the third time it took a second but it started grumbled for a min but stayed on. i let it warm up for 15 min it was very cold. when i came back out i noticed my radio stations were all unprogramed and the ses was off. it also started doing that thing where the rpms start bouncin down irraticly like its gonna stall. so i shut it off and rstarted it , it ran fine the rest of the day. and started ok today. anyone know why did the cars computer reset?? also i hav a bad radio groun i think i can hear the alt through the radio idk if the 2 would be connected. thanks for any input
  2. #2 Re: computer reset itself???
    GT Level Member TheAce144's Avatar
    Dec 2010
    Montreal, Canada
    Check out you battery wires to and look if they are well connected. Also, cars have a harder time starting up in cold temperatures...My car did the same thing and since I replaced the battery, it does not do it anymore.
    04 GTP CompG: SSAC Headers, 3.6" Modular Pulley System, Autolite 104, NGK Spark Plug Wires, CAI, ZZP 180 T-Stat, Overkill PCM (Custom Street Tuning By Will), Goodyear Eagle F1 Tires, Hawk HPS Brake Pads, Magnaflow Magnapacks 4", SE Front Fascia
    Check Out My Car! ---
  3. #3 Re: computer reset itself???
    defiantly sounds like a bad battery, mine did the same thing when it started to get cold, new battery, all better.
    have the alternator checked to, auto zone usually has a tester they hook up to the battery to see if the alternator is charging or not.
  4. #4 Re: computer reset itself???
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    Same story here, accept mine was an optima that failed load tests.Had the battery for 3 months and it didnt act up untill it was cold.
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  5. #5 Re: computer reset itself???
    Jul 2010
    syracuse, ny
    battery and alternater are new and they been tested they are good.
  6. #6 Re: computer reset itself???
    redneck tennessee
    You might want to check your bodyground connection then.I havent had any problem in the past but i have heard that these cars dont have the best bodyground.Might b good to check seems how its free to do it.
  7. #7 Re: computer reset itself???
    GT Level Member 98GPGT2D's Avatar
    Ontario, Canada
    Make sure the connections at the battery are CLEAN and TIGHT. No Adjustable wrenches or vicegrips for this job, use the proper wrench or socket. Parts stores sell battery terminal cleaners for around 5 bucks, make sure the terminals are good and clean.
    Jay
  8. #8 Re: computer reset itself???
    Jul 2010
    syracuse, ny
    giong to check that ground as soon as it not this freaking cold out lol! also battery terminals are properly cleaden and tightened. thnks
  1. zzp 1.0 pcm- Question about reset
    By TheBeastGTP in forum General Tech Discussion
    Last Post: 07-24-2010, 10:02 AM
  2. SES light reset?
    By 98GRANDPRIXGTP in forum General Tech Discussion
    Last Post: 03-31-2010, 11:38 AM
  3. oil monitor in DIC wil not reset
    By jojosgrampa in forum Introductions/Noob Questions
    Last Post: 05-24-2009, 01:52 PM
  4. reset abs
    By 99gpse in forum Off Topic Discussion
    Last Post: 04-11-2009, 09:02 PM
  5. how do i reset the theftlock???
    By 94GTRoyalty in forum 3.4L V6 (LQ1) DOHC
    Last Post: 07-29-2008, 03:08 PM
