Thread: Magnaflow Cat
Results 1 to 20 of 21
  1. #1 Magnaflow Cat
    delaware
    Hey, I recently had speed daddy headers installed on my car, and now i need to put a Cat on it for inspection next month. Would the cat below fit the headers? it looks like i would need a cat with a 3inch inlet/outlet.
    (headers)
    PONTIAC GRAND PRIX GTP 97-08 3.8L RACING HEADER/EXHAUST | eBay
    (Cat)
    MagnaFlow Ceramic 53000 Series Catalytic Converters - 04EXH - PFYC.com
  2. #2 Re: Magnaflow Cat
    Just buy a 3" in/out converter and bolt it in place of the straight pipe before it bolts up to your catback.
    Also, buy a 3" converter from EBay...because PFYC is expensive as hell.
  3. #3 Re: Magnaflow Cat
    delaware
    Thanks for the fast response. I did look on Ebay and all that i found where the high flow cats that are over $100 and one bullet cat that was close to $100 so surprisingly pfyc was cheaper. Arent the only ones that bolt on are the high flow cats? like the one below. If thats the case i would really just prefer the bullet cat since i want to keep the cat on the car. Do you have a cat that u prefer? Sorry if i sound kinda slow about this subject but i don't know a lot about cats at all.
    http://cgi.ebay.com/ebaymotors/ws/eB...m=260650801610
  4. #4 Re: Magnaflow Cat
    Does it need to DO anything?
    If not.... Frozen boost has a "non-cat" for less money.
  5. #5 Re: Magnaflow Cat
    GT Level Member GtpKo's Avatar
    Best place on Earth
    What about the 99009HM? $90-ish
    2002 GT F23 5-speed swapped, SPEC stage 2+ clutch, ZZP Power Logs, E-brake handle swap.
  6. #6 Re: Magnaflow Cat
    delaware
    Quote Originally Posted by GtpKo View Post
    Where is that from?
  7. #7 Re: Magnaflow Cat
    Reynosa,Mexico
    Quote Originally Posted by misterman View Post
    Interesting i have never heard of a non cat. What does it do? will it clean the emissions? Will it make the car a little quieter i don't really like the huge grumble/raspsy sound it makes now. Which i think it makes that noise because i have an exhaust leak, and i am hoping that welding on a cat will solve that issue. Also is there any gains? or will it rob the gains since a "non-cat" is going back on?
    Will this also help with the grumble/raspsy sound it makes? Cause mine doesn't have a CAT either.
  8. #8 Re: Magnaflow Cat
    delaware
  9. #9 Re: Magnaflow Cat
    its a pipe with a cat body welded to it.
    Doesnt do a thing for emissions.
  10. #10 Re: Magnaflow Cat
    delaware
    Ah i need an actual cat to pass inspection coming up. I was happy to about spending less money.
  11. #11 Re: Magnaflow Cat
    99009HM would work.
    Or the metallic equivalent.
    Hotexhaust.com
    or amazon.com should have them.
  12. #12 Re: Magnaflow Cat
    delaware
    Okay great. Thanks a lot for all the info and help peeps.
  13. #13 Re: Magnaflow Cat
    delaware
    One more question. So the one below would fit? i am just a little skeptical because of how long it is. I guess it dosent matter since it is being welded on?
  14. #14 Re: Magnaflow Cat
    I'd opt for one of the HM series because most of the other ones supposedly don't do so well for emissions.
    Sort of a "throw it on and I'll need a new one next time around" cat.
  15. #15 Re: Magnaflow Cat
    delaware
    When i looked up the 99009HM series on the fit guide did not show the grand prix. Or does that not matter since it is going on after market headers? Also it states that it is non-carb complient. What does that mean?
    http://www.amazon.com/dp/B001HMAZ32/...SIN=B001HMAZ32
  16. #16 Re: Magnaflow Cat
    to be carb compliant it needs to be designed for that vehicle alone.
    It wont matter because its for aftermarket exhaust.
  17. #17 Re: Magnaflow Cat
    delaware
    Okay great thanks again. Placing order as we speak lol.
  18. #18 Re: Magnaflow Cat
    Glad you got it figured out...but yes...if you could get away with it; get a fake converter from Frozen Boost
  19. #19 Re: Magnaflow Cat
    I was under the impression the rest of your catback would be the cause of that.
  20. #20 Re: Magnaflow Cat
    A catless system will have a little more "tone" to it...deeper sounding if you will...you WANT a resonator and non-chambered mufflers to keep the exhaust quiet since 3800's sound like crap regardless.
  1. magnaflow dp
    By Wakeboy1337 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-01-2011, 11:55 AM
  2. Magnaflow 30% off?
    By Lawngoose in forum Off Topic Discussion
    Last Post: 04-27-2010, 07:30 PM
  3. Magnaflow Cat
    By impala04ss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-03-2009, 01:27 AM
  4. magnaflow for V8 on a V6
    By 07 GPGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-24-2008, 10:23 AM
