Thread: Car not warming up enough = Worthless heat?
Results 1 to 14 of 14
  1. #1 Car not warming up enough = Worthless heat?
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    My 07 GTP wont heat up. It will get close to the halfway point (200 I assume) but 90% of the time it stays just above 1/4 and the heat is horrible cuz of that. I just changed the thermostat and bleed it just untill it ran solid coolant. Does anyone have any other guesses? Could I just need a flush theres no leaks anywhere.
  2. #2 Re: Car not warming up enough = Worthless heat?
    its possible your heater core is already plugged up.
  3. #3 Re: Car not warming up enough = Worthless heat?
    Oct 2008
    IL
    The engine itself isnt getiing to running temp and staying there tho? You still think heatcore? Anything I can run through it for this or is it as intense of a job as I remember??
  4. #4 Re: Car not warming up enough = Worthless heat?
    Oct 2008
    IL
    So I checked both hoses going to and from the heater core both warm. Could not enough collant make it not warm up enough. Thats backwards to me but could it happen?
  5. #5 Re: Car not warming up enough = Worthless heat?
    GrandPrix Junkie
    St. Louis
    Not enough coolant in the system (i.e.- air is still somewhere in the system) could cause low heat. Does the temp gauge bouce around at all?Have you tried warming the car up for 15 min. or so, then driving it? Might have a bad thermostat.
  6. #6 Re: Car not warming up enough = Worthless heat?
    Oct 2008
    IL
    Quote Originally Posted by FordMan77 View Post
    Im going to give bleeding the system a shot again today or tomorrow. Apperantly its a longer prcess than I gave it. I already did the thermastat but yea it bounces around a lil but mainly jusy doesnt get to operating temp.
  7. #7 Re: Car not warming up enough = Worthless heat?
    Topeka, KS
    Also it is possible that the new Tstat you got is bad as well.
  8. #8 Re: Car not warming up enough = Worthless heat?
    GTX Level Member cerick08GP's Avatar
    Quote Originally Posted by chevyy1212 View Post
    From what you have wrote I can tell you your car is heating up normally, and that your thermostat is/was functioning normally. Your problem isn’t the coolant temperature. My car heats up exactly as you have indicated, you should probably expand your search. I would be more concerned about having enough coolant in the car vs bleeding it for the tenth time. Have you checked for proper air flow? You might have a damper issue.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  9. #9 Re: Car not warming up enough = Worthless heat?
    Charles City, IA
    If it is not blowing very hard, check your cabin filter underneath the windshield wiper panel.
    SMGPFC Two Nipple General
  10. #10 Re: Car not warming up enough = Worthless heat?
    Oct 2008
    IL
    No its blowing good. Im thinking its a air in the lines issue. I just dont think i gave it enough time and I think I just did it well not really good at all.
  11. #11 Re: Car not warming up enough = Worthless heat?
    GT Level Member donmega's Avatar
    St louis, mo
    have you checked the coolant temp sensor? common failure
    "well we can spend 1000s throwing parts in it and hope that fixes the problem or we can diag it correctly and change the .50 cent fuse...lets ask the owner what he wants to do" --Walt R.--
  12. #12 Re: Car not warming up enough = Worthless heat?
    chicago ill
    you need to look at the resistance sencer. is your radiador fan is on all the time pecause if it is your resistance senser is not workin is so it thinking that the engine is over heatin wen is not en is asking wor cooling
  13. #13 Re: Car not warming up enough = Worthless heat?
    Dec 2010
    s.carolina
    does your car have those bypass tubes behind the main pully water pump? if so are they leaking? had same problem,change them and had heat. poor set up by gm plastic part they crack
  14. #14 Re: Car not warming up enough = Worthless heat?
    Oct 2008
    IL
    So many things to check when its 5 degrees out... Darn thanx for all the tips tho.
  1. Another worthless ABS/TC question from a new member
    By alexmerchant in forum Brakes/Suspension/Chassis
    Last Post: 03-16-2010, 10:17 PM
  2. No Heat, Need Help.
    By speed24 in forum General Tech Discussion
    Last Post: 12-17-2009, 03:50 PM
  3. Heat and A/C??
    By lorenzojay in forum General Tech Discussion
    Last Post: 09-28-2009, 08:43 PM
  4. GM parts listing worthless, need help finding hose
    By hunter_alexander in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-23-2008, 11:07 PM
  5. Studies Say Clearing Land for Biofuels Will Aid Warming
    By GeddyLee in forum Off Topic Discussion
    Last Post: 02-11-2008, 02:28 AM
