Thread: how to use a fuel pressure gauge?
Results 1 to 3 of 3
  1. #1 how to use a fuel pressure gauge?
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    im going to be getting my hands on a fuel pressure tester to help diagnose the hard cold start on my GS, but i need to know what i am looking for when testing some different things.... on the list of possible culprits are Fuel pressure regulator, leaking injector (though i dont seem to have a misfire condition after changing plugs/wires, but further test driving required to verify) or weak fuel pump check valve. I am assuming that testing the fuel pump check valve is relatively easy, involving having the gauge hooked up to measure weather or not the pressure drop is within the specified range after sitting for x number of hours. what's the range this should be? if that checks out, what do i need to watch for/how do i test the other items?
  2. #2 Re: how to use a fuel pressure gauge?
    Hoffman/Schaumburg, IL
    I know you can check the regulator by having the gauge hooked up, and car running and just pull the vacuum line off the regulator, and pressure should rise(no vacuum= WOT=higher reqired fuel pressure)
  3. #3 Re: how to use a fuel pressure gauge?
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    Also pull the vac line off of the regulator with the car running and if fuel comes out of the vac port the regulator is shot.
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  1. Fuel pressure gauges
    By Sabrewings in forum General Tech Discussion
    Last Post: 07-28-2008, 08:03 PM
  2. Fuel pressure and fuel in the rails
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:03 AM
  3. anyone have a Prosport fuel pressure gauge?
    By fst in forum PCM Tuning
    Last Post: 04-02-2008, 06:38 AM
  4. Pressure Supply Fuel Line
    By GreenNirvana101 in forum General Tech Discussion
    Last Post: 03-26-2008, 10:08 PM
  5. After Market Fuel Pressure Regulator
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2008, 02:14 PM
