Thread: 97 l32 camaro
Page 2 of 8 FirstFirst 1234 ... LastLast
Results 21 to 40 of 160
  1. #21 Re: 97 l32 camaro
    SE Level Member 97RS's Avatar
    Dec 2010
    miami fl
    i wasn't watching the tv there.
  2. #22 Re: 97 l32 camaro
    Dec 2010
    miami fl
    almost done, dam rain yesterday didn't let me work on the car so i'll see if i can work on a bit before work till next week, as far as tuneing goes i got no help from pcm for less. i was real disappointed since they say they do grandprix tuning and camaro tuning as well. and the tune seems simple.
  3. #23 Re: 97 l32 camaro
    if they can tune an ls1 they should be able to do your car.
    also.... LOL at the hanna......
  4. #24 Re: 97 l32 camaro
    Feb 2009
    flintnasty MI
    I have tuned many swaps before, hit me with an email if you get stuck.
    sc10wolf --cat-- gmail.com
  5. #25 Re: 97 l32 camaro
    Been watching your thread as I might like a L67 firebird one day (HP minus the V8 )..
    If you got a tuner or find someone that can at least do the basics, might be able to give you a head start.
    Assuming you move all the needed electronics from the L67 over (MAP sensor, etc), I have had very good luck moving the engine section of bins in the older years (newer Chevy's not so much as to call it perfect, but close). Basically, you did what a 97 Grand Prix GT owner did as far as cross breading engine/trans.. He changed his L36 out for the L67 and needed the transmission section of the original PCM because the transmission is different in that year from the rest of the GTs...
    Anyway, we could take you bin, leave manual transmission section untouched, and just swap out the l36 with the l67 programming. You will just have to work out the balance between the engine/trans settings (which shouldnt be as difficult as you are running a manual transmission so you wont really have to contend with shift points, pressure, toruqe management, etc). As long as we dont touch the electronics or programming for it that make communication with BCM/gauge cluster, those things should keep working.
  6. #26 Re: 97 l32 camaro
    Feb 2009
    flintnasty MI
    I have ran a manual throttle cable camaro file a few times with an automatic bin file... It works pretty well.
  7. #27 Re: 97 l32 camaro
    Dec 2010
    miami fl
    ive done it 2 when i did a t56 swap to an lt1, its just that the speedometer doesn't read right.
  8. #28 Re: 97 l32 camaro
    Feb 2009
    flintnasty MI
    A malfunctioning speedo would not be my definition of "works alright".
  9. #29 Re: 97 l32 camaro
    Indeed, and hopefully it was at least calculating the speed in the PCM correctly for the MPH referenced tables.
  10. #30 Re: 97 l32 camaro
    Dec 2010
    miami fl
    well everyone i got her running today without the belt to see how it all went, i used the 97 gtp fuel injectors and tb but use my 1 bar map sensor from the camaro. only one thing that's concerning me and that's the supercharger pulley spins while the engine is on and no belt on. is that normal or is the bypass valve not working?
  11. #31 Re: 97 l32 camaro
    Troy OH
    probably normal. the air has to come through it right? seems to me like the bypass valve would open when you kill throttle and there is too much pressure built up. there's motion of the air through the screws, it's bound to cause movement
  12. #32 Re: 97 l32 camaro
    Dec 2010
    miami fl
    ill check tomorrow to make sure that flap is opening.
  13. #33 Re: 97 l32 camaro
    Troy OH
    keep us posted. good work on the swap man
  14. #34 Re: 97 l32 camaro
    the pulley will spin without the belt, but you can grab onto it and stop it. the air moving through the rotors is just making them rotate, in turn spinning the pulley.
  15. #35 Re: 97 l32 camaro
    Dec 2010
    miami fl
    oh ok thanks, let see if i can get her to the exhuast shop to connect my yipe and then ill see who can tune it for me since i want it tuned asap.
  16. #36 Re: 97 l32 camaro
    GT Level Member zipper's Avatar
    Dec 2008
    Shelby, MI
    Very cool Camaro! I'll be keeping an eye on this post to see how it all turns out.
    Good luck, I love unique cars!
    NA dyno: 222whp
    Novi 1000 dyno: 348whp
    Novi 2000 dyno: 372whp Best 1/4 mile: 13.2634@105.12mph
  17. #37 Re: 97 l32 camaro
    SE Level Member speedy2's Avatar
    NW Florida
    Nice. is that engine all stock? I'd like to know how quick the car is with a stock L32. Something I've always wondered. I had a '94 Camaro with the 3.4L. Oh boy did I hate that thing as far as performance went.
  18. #38 Re: 97 l32 camaro
    Dec 2010
    miami fl
    Quote Originally Posted by zipper View Post
    it should be all good, i just hate having budget builds. sometimes u have to cut corners while still making **** functional. when shes all done running and tune ill take the time to do a write up with pictures in case anyone else would like to do it in the future they know what there getting into.
    Quote Originally Posted by speedy2 View Post
    all stock down to the factory sparkplugs. motor has 20k miles and exhaust manifolds are 00 and up factory gm 3.8 tubular manifolds. i had a 94 camaro with a 3.4 5 speed back when i was at high school i bought the car for 300 bucks, and lasted me 2 years and never gave a problem. i just hated how much it rattled in high rpms but yeah she was slow but hey it smoked all the 3.8 stangs and a ton of civics lmao.
  19. #39 Re: 97 l32 camaro
    Arizona
    damn this is sweet..
    and for the exhaust, i suggest keeping it quiet, these engines sound best that way
    '00 GT- nothing special
  20. #40 Re: 97 l32 camaro
    Dec 2010
    miami fl
    Quote Originally Posted by coreygnar View Post
    i have a facotry high flow 3inch y pipe and then a aftermarket high flow cat. it goes down to 2 1/2 after the cat all the way back to the high flow factory replacement muffler. inside the muffler you can see all the way threw the other side and it has dual exits and its real quiet. im not sure if the drop from 3 in to 2 1/2 is bad for the supercharger. i hope not.
  1. LT1 Camaro
    By ls1camino in forum Track Sessions and Kills
    Last Post: 11-21-2009, 02:14 AM
  2. Camaro vs Evo
    By SlowM90 in forum Track Sessions and Kills
    Last Post: 08-30-2009, 03:26 AM
  3. Camaro
    By bloxmagic in forum Track Sessions and Kills
    Last Post: 07-03-2009, 02:09 PM
  4. Best Camaro EVER!
    By J GTP in forum Off Topic Discussion
    Last Post: 06-25-2009, 07:00 PM
  5. GXP VS New Camaro
    By Black GXP in forum Track Sessions and Kills
    Last Post: 06-23-2009, 01:23 AM
