Thread: l32 aluminum blower gasket reusable?
Results 1 to 20 of 21
  1. #1 l32 aluminum blower gasket reusable?
    SE Level Member 97RS's Avatar
    Dec 2010
    miami fl
    i notice this motor had copper exhaust manifold gaskets and a aluminum blower gasket. are they reusable?
  2. #2 Re: l32 aluminum blower gasket reusable?
    I've reused the exhaust gaskets which to my knowledge are stainless mls gaskets. (at least on the motors I've pulled apart)
    The blower gasket.. tough to say, it's a good gasket, how's it look overall...flattened gasket area??
  3. #3 Re: l32 aluminum blower gasket reusable?
    you might get lucky and it'd reseal so long as youre able to remove it and put it back in without destroying it. i know the paper gaskets are pretty much one time use considering youll rip the hell out of it the next time you take it off.
  4. #4 Re: l32 aluminum blower gasket reusable?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    yes they are reusable, and they are expensive.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  5. #5 Re: l32 aluminum blower gasket reusable?
    Dec 2010
    miami fl
    motor has 20 k, and it looks brand new.
  6. #6 Re: l32 aluminum blower gasket reusable?
    GT Level Member starscream5000's Avatar
    Kentucky
    Only one way to find out. Spray a light coating of permatex brake quite on both sides of it before re-installing, make sure you clean it off good first with brake cleaner though. This method is used in the supra crowd a lot for sealing MLS head gaskets. If this holds up on a supra boosting 20+psi, it will hold up on a metal S/C gasket.
    2005 GTP - AL 605's gapped at .055", SD headers, WAI with 9" cone air filter, 180 degree t-stat, green coolant, otherwise stock.
  7. #7 Re: l32 aluminum blower gasket reusable?
    Dec 2010
    miami fl
    what about the intake manifold gasket? i notice is also aluminum, is that also reusable or am i pushing it?? thanks for the help guys
  8. #8 Re: l32 aluminum blower gasket reusable?
    Hagerstown,Md
    Id get a new lower IMO
  9. #9 Re: l32 aluminum blower gasket reusable?
    Charles City, IA
    I would get a new lower.
    SMGPFC Two Nipple General
  10. #10 Re: l32 aluminum blower gasket reusable?
    Dec 2010
    miami fl
    aight guys u been real helpful. thanks.
  11. #11 Re: l32 aluminum blower gasket reusable?
    Dec 2010
    miami fl
    can i get the lower intake manifold gasket from felpro or do i need to get one from the dealership?
  12. #12 Re: l32 aluminum blower gasket reusable?
    Never Never Land
    Irrelevant...but im assuming you have a 97 RS?
  13. #13 Re: l32 aluminum blower gasket reusable?
    Dec 2010
    miami fl
    Quote Originally Posted by 4THGENCAMAROFAN View Post
    yeah, im in the middle of swapping the l32 into the car. the engine and everything has been bolted on so far onto the car and test fitted. i removed the intake manifold and supercharger to get it modified to fit onto the car. got to seal up the tb warmer and modify the supercharger housing. i will be useing a 97 GTP l67 tb i got from the junkyard. so far everything seems fine for now. just taking it step by step. i'll post some pics when its all put together and done. everything has been going as plan and i put together and rebuilt allot of lt1s cars over the years but never worked on a gtp so its all new to me with this fwd v6 stuff is new to me but im getting it pretty quick.
  14. #14 Re: l32 aluminum blower gasket reusable?
    Never Never Land
    sweet another m90 camaro.
  15. #15 Re: l32 aluminum blower gasket reusable?
    Dec 2010
    miami fl
    its been done before? im keeping all accorys and ac and heater, everything. its a 97 camaro RS with the y87 package, t5 5 speed, leather interior and rear posi with disc brakes, and t tops. i done allot of things to adapt this engine but just taking it step by step.
  16. #16 Re: l32 aluminum blower gasket reusable?
    yes, its been done a few times. most guys skip it and just go turbo because of more room, but the m90 can make the car fun.
  17. #17 Re: l32 aluminum blower gasket reusable?
    Never Never Land
    Quote Originally Posted by 97RS View Post
    i thought the y87 package was the rear disks and posi. or was that th y86?
    I thought about doing an m90 top swap but i thnk im gonna go turbo...more power and easier.
  18. #18 Re: l32 aluminum blower gasket reusable?
    Dec 2010
    miami fl
    lol not sure i have both, but yeah man i like the supercharger much better and yeah real different.
  19. #19 Re: l32 aluminum blower gasket reusable?
    Never Never Land
    I just checked...the Y87 package was available only on the sixxers. It consisted of 3.23 gears since you have a 5 speed(envious), a 14.4:1 steering rack which was the same on a z28, all wheel disc brakes and dual muffler outlets.
  20. #20 Re: l32 aluminum blower gasket reusable?
    Dec 2010
    miami fl
    yeah i have all that, 30th anniversary leather seats, automatic head lights, power window/doors, keyless entry and factory alarm. 6 speaker system ext. **** is fully loaded but v6 and 5 speed. i found that real funny.
  1. Blower motor doesn't turn on - no signal to blower control module?
    By Joe942 in forum General Tech Discussion
    Last Post: 01-17-2011, 06:12 PM
  2. LIM aluminum gasket- what kind of adhesive and where to apply?
    By colindunn in forum Off Topic Discussion
    Last Post: 06-18-2010, 12:25 PM
  3. Silicone baking sheet as a blower gasket
    By kfish in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2010, 09:36 AM
  4. No Aluminum LIM Gasket for N/A Engine?
    By SuperSport in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-10-2009, 12:36 AM
