Thread: wondering if I can run a 3.4 pulley on my car by boosting octane?
Results 1 to 14 of 14
  1. #1 wondering if I can run a 3.4 pulley on my car by boosting octane?
    North Carolina
    I am wondering if I could get by for awhile by boosting premium octane (93) to the 94-96 range? I have a pcm tuned by 3800performance for a 3.4 setup,intake,colder ngk plugs and fresh plug wires. I know i at least need a downpipe and or p-log otherwise, but can't right now.
  2. #2 Re: wondering if I can run a 3.4 pulley on my car by boosting octane?
    wait till you get a plog, downpipe and or headers.
    just pumping up the octane wont do anything really.
  3. #3 Re: wondering if I can run a 3.4 pulley on my car by boosting octane?
    ...cam, youre wrong.
    yes, you could probably get away with bumping up the octane and running a 3.4 pulley. however, bumping up the octane by one or two points will net you nothing and youre better off on a stock pulley. you wont be able to get any real amount of octane unless you mix your own race gas and use a few gallons of that every tank.
    therefore, dont even debate it and work slowly by accumulating parts and then putting them all on later.
  4. #4 Re: wondering if I can run a 3.4 pulley on my car by boosting octane?
    Hagerstown,Md
    if you fill with cam2 112 or 116 sure. Otherwise i wouldnt do it
  5. #5 Re: wondering if I can run a 3.4 pulley on my car by boosting octane?
    That's how it was done in the old days...stupid small pulley...stupid high octane...it killed the knock for sure.
  6. #6 Re: wondering if I can run a 3.4 pulley on my car by boosting octane?
    wutever. its still not even close to worth it to be putting race gas in the car, cuz it cost so dam much.
  7. #7 Re: wondering if I can run a 3.4 pulley on my car by boosting octane?
    SE Level Member NineD9GT's Avatar
    Dec 2008
    PA
    Yeah, it costs enough just using 93!
    99 GP GT L26 bottom end, Intense stage II cam, Ported L67 heads w/ LS6 springs, LS1 valve seals, 42.5# injectors, ported sc/intake, custom LS1 TB and MAF, custom FWI, 3.4 mps, NGK TR6, ZZP wires, 180 stat, etc...
  8. #8 Re: wondering if I can run a 3.4 pulley on my car by boosting octane?
    good thing there are recipes all over the web for making your own race gas on the cheap.
  9. #9 Re: wondering if I can run a 3.4 pulley on my car by boosting octane?
    SE Level Member 1998DaytonaPaceCar's Avatar
    Dec 2010
    Lawton / Fort Sill, OK
    yeah $6.70 a gal for 110 here at phillips 66 lol
    1998 Daytona Pace Car #1371 of 1500
    Mods: Pacesetter headers, 3.4" S/C pulley, 180ยบ t-stat, K&N FIPK Intake kit, Cross drilled rotors, 18" rims, DHP PCM, Custom exhaust (Cherry Bomb glasspack acting as resonator, 2X Corsa sport mufflers from my old 06 GTO R.I.P.)
  10. #10 Re: wondering if I can run a 3.4 pulley on my car by boosting octane?
    Dec 2010
    Noble, Oklahoma
    Quote Originally Posted by 1998DaytonaPaceCar View Post
    Lol well in the okc 110 is only $6.00 look at the savings!! lol
    Boostin To A City Near You
  11. #11 Re: wondering if I can run a 3.4 pulley on my car by boosting octane?
    Dec 2010
    Noble, Oklahoma
    anyway on the subject i have a 3.4 with 3in cat-less dp, and exhaust,cai,ngk's, accel wires running 93 w/octane booster every tank and maybe on a bad day hit 2 degrees kr with no pcm tune. i guess every car varies. like some people have more mods then me with the same pulley and are pushing 10-12 psi. I spike 9-9.5 and hold around 7-8 psi just varies i guess
  12. #12 Re: wondering if I can run a 3.4 pulley on my car by boosting octane?
    More boost means you need more flow mods...I'd be scared if my 3.4" setup was making 12psi.
  13. #13 Re: wondering if I can run a 3.4 pulley on my car by boosting octane?
    my car made 11psi on the 3.2 in summer, 13psi on the 3.4 in winter. it was a beast.
  14. #14 Re: wondering if I can run a 3.4 pulley on my car by boosting octane?
    Don't make me say boost stack to get you started
  1. Boosting Under Load? Normal?
    By BwolfGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2010, 03:05 PM
  2. What Octane gas to use?!!!
    By Redbirds2230 in forum General Tech Discussion
    Last Post: 10-27-2009, 03:55 AM
  3. 91 Octane On Smaller Pulley
    By GPGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-27-2009, 11:54 PM
  4. Octane
    By Davisgtp in forum Off Topic Discussion
    Last Post: 03-18-2009, 10:20 AM
  5. Boosting Pulley size
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-22-2008, 05:07 PM
