Thread: EGR removal affects anything?
Results 1 to 8 of 8
  1. #1 EGR removal affects anything?
    SE Level Member 97RS's Avatar
    Dec 2010
    miami fl
    hey guys i was wondering if there would be any gain or loss from removeing the egr. im doing a swap to my camaro but im not sure if reinstalling the egr would be worth it. i already have the motor in the car and everything seems to be going as planed. i can still adapt the egr with little issue but im not sure it its worth it. thanks.
  2. #2 Re: EGR removal affects anything?
    EGR's help fuel mileage and cylinder temps. If you can, run it.
  3. #3 Re: EGR removal affects anything?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    X2 what bill said. only real reason not to run it is with a Intercooler. I still do with my intercooler but it gunks them up
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  4. #4 Re: EGR removal affects anything?
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    I removed mine because it's ugly and it leaked. I haven't noticed much of a change in fuel mileage, and I deleted the EGR DTC code that it threw.
  5. #5 Re: EGR removal affects anything?
    GTX Level Member colindunn's Avatar
    Aurora, IL
    it was there for a reason to begin with. keep it if you can otherwise you dont "need" it.
  6. #6 Re: EGR removal affects anything?
    id take mine off my subaru if i cared. id never run one on the GP, it gets in the way of everything.
  7. #7 Re: EGR removal affects anything?
    Charles City, IA
    Mine has been off for a long time now. Still could pull 30 on the interstate.
    SMGPFC Two Nipple General
  8. #8 Re: EGR removal affects anything?
    GT Level Member djrepoman's Avatar
    columbus ohio (polaris)
    Removed mine and deleted the codes a year ago, no reportable issues here, Removing it makes thing easier to work on, and it looks better
    2000 GT ,E85 powered, and still slow
    98 GTP Stock
  1. S/C Removal Gaskets
    By TeeWX in forum General Tech Discussion
    Last Post: 03-23-2010, 01:08 PM
  2. engine removal
    By aubry118 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2010, 04:33 PM
  3. Transmission Removal help
    By jagman454 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-15-2010, 11:42 PM
  4. blower removal
    By gotboost3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-10-2009, 06:28 PM
  5. Stud removal
    By TheOtherNick in forum How To Write-Ups/Tech Tips
    Last Post: 01-04-2009, 11:21 PM
