Hey guys. Recently my car has had somewhat of a starting issue. Car would have trouble starting cold. She cranks fine and usually it just takes a couple turns of the starter to get her to fire up. Most of the time when its warmed up, there is less of a problem. At first it was random as to when it would do this but has become more consistent lately. Couldnt hear the fuel pump priming properly so i changed it... seems slightly better but still not "turn key".
Along with this starting issue... i had begin to notice a high rpm "flutter".... installed an aeroforce and i see im getting KR whenever i get into boost. Prior to changing the pump i figured that the pump possibly wasnt giving the motor enough fuel... however the KR remains. This flutter of the tachometer has gotten progressively worse over the past couple months. I assume what im seeing/feeling is knock retard. Otherwise the engine runs perfectly. No trouble codes or misfires showing up.
I have a good understanding of what KR is and its purpose however i dont understand why i have so much. Ive seen as high as 8 degrees and at that point i stopped using boost... this is definately not false knock. The car is basically stock. I have a CAI, stock 3.8", silencer slits filled and a very slight port job on the blower. I know some people dont like filling the slits but its been holding up for over a year and a half and no problems. Tune is stock as well. All the maintenance is good on the car.... plugs... filters... fluids.. etc. Shes got 136,000 miles. No vacumm leaks that i can finsd. LIM done 40k ago.
Parts that have been recently changed are:
Fuel Pump
FPR
O2 Sensor
MAF
IAC
I honestly have no clue as to why i have so much KR (or any at all for that matter)... i could use any advice you guys may have. thanks in advance
