Thread: 01 GTP. Car shakes when in Neutral and Park.
Results 1 to 10 of 10
  1. #1 01 GTP. Car shakes when in Neutral and Park.
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    Chats
    Ok my GTP has about 67K on it. Has clean oil, less than 100 miles ago the injectors were cleaned with Sea Foam, and had spark plugs changes (AC Delco).
    When the vehicle is in park or neutral (i like to put into neutral sometimes so I dont have to hold the brake. Im used to stick) it will rock a little bit. The RPM Gauge doesnt bounce our anything out of the ordinary. There are no odd sounds coming eather. Just a light rumble in the seat and floor. It will happen about every 7 seconds. It is definitely noticeable by me and a passenger.
    I am a little concerned on why this is doing this. Any suggestions?
    Thank you!
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  2. #2 Re: 01 GTP. Car shakes when in Neutral and Park.
    Barksdale AFB, LA
    Chats
    Every 3800 I've ever sat in does that. Normal operation.
    2009 Subaru Impreza WRX STI
  3. #3 Re: 01 GTP. Car shakes when in Neutral and Park.
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Chats
    My car shakes some too, but it's probably the cam.
    When did you start noticing the shake, or has it always been there?
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  4. #4 Re: 01 GTP. Car shakes when in Neutral and Park.
    GT Level Member johnnyj773's Avatar
    May 2008
    Chicago(southside)
    Chats
    i noticed it on mine too.
    Wizaired cai,taylor 8mm wires,ngk tr55 plugs, msd coils.slp power flo exhaust w/gtx tips. future mods:zzp 1.0 pcm,slp headers, zzp hv3 uim runners ,zzp hv tb,gmpp sway bars,kyb agx struts,18"A.R.M:Rogues wrapped in firestone firehawk gt's.that's all performance wise.
  5. #5 Re: 01 GTP. Car shakes when in Neutral and Park.
    Apr 2008
    Chillin at the Beach , VA
    Chats
    With the miles, I'd check the condition of the motor mounts and braces. Mine had a slight shake to it and when I pulled the motor, found I had a busted motor mount. Now I don't seem to have the shake anymore. Just something to think about.
  6. #6 Re: 01 GTP. Car shakes when in Neutral and Park.
    Bastard Reptile's Avatar
    Kansas City, MO
    Chats
    1492
    It kind of sounds like the random misfire that every single car I've owned has had before. But then again, it's difficult to say how it feels to you vs. how it feels to me.
  7. #7 Re: 01 GTP. Car shakes when in Neutral and Park.
    Bartlett, IL
    Chats
    Yea, its not really a alarming feeling. Just a few small jolts about ever 7 - 10 seconds. My brother's 04 GTO does it way worse! His has 23K on it and the damn thing rumbles at a dead stop sometimes. I make fun of him about.
    And my GTP's air is colder than his GTO
    BUT!! GTO.... That car is crazy fast! it will do 120mph NO PROBLEM in 6th sitting at about 3.5K rpm. Its fun Bad gas though >:| Premium too!
    How To: E-Brake Pwn
  8. #8 Re: 01 GTP. Car shakes when in Neutral and Park.
    NE Ohio
    Chats
    im gonna say its either a misfire, or a bad motor mount.
  9. #9 Re: 01 GTP. Car shakes when in Neutral and Park.
    Chats
    wit my experience with cars. i'd check, already stated, the motor mounts.
  10. #10 Re: 01 GTP. Car shakes when in Neutral and Park.
    Grand Rapids, MI
    Chats
    I agree on the misfire. Mine is doing it right now and I'm getting misfires on cyl #3. Do you have the SES light on? Is it flashing too by chance? It can be a pending code too, if it's not lit up. If you have an OBD II tool check the codes and if not, stop at an Autozone and they can check for free.
  1. Pontiacs in the Park-VA
    By mlambert in forum Shows and Events
    Last Post: 06-03-2008, 09:06 PM
  2. Car shakes after lowering
    By Smokedgtp in forum Brakes/Suspension/Chassis
    Last Post: 04-30-2008, 09:17 PM
  3. Park Ave owners welcome?
    By gonneville in forum Introductions/Noob Questions
    Last Post: 01-11-2008, 10:13 AM
