Thread: MAF Sensor
Results 1 to 5 of 5
  1. #1 MAF Sensor
    May 2008
    I got the SES light today and took it to autozone to see what the code was. It's the P0102 (MAF low input or something like that). This is my second time having this code and was wondering about my options. Obviously I could go out and buy a new MAF sensor right away, but what about checking for leaks and cleaning the sensor? Should I try these before buying a new sensor? I've also heard that the MAF sensors were poorly made in the first place, is it worth $130 for a new one? How do I check for leaks and/or clean the sensor?
    BTW my car is a 97 GTP.
  2. #2 Re: MAF Sensor
    PA
    First thing I would try to do is clean the MAF. They can get dirty, especially if you have an oiled air filter. So clean it first to see if that solves the problem.
    If not, I would buy a good used GM one from Ed Morad. I would imagine it would be less than $50 for a good used MAF sensor.
    2001 GSE
  3. #3 Re: MAF Sensor
    May 2008
    Ed told me $65 for a used MAF for mine
  4. #4 Re: MAF Sensor
    GT Level Member DWosik13's Avatar
    Detriot,MI
    i just had this problem ed morad told me 65 shipped and luckily i live near Detroit so from northern Ohio to me it was only one day until it got to me i put it in and it worked
  5. #5 Re: MAF Sensor
    Grand Rapids, MI
    A few years ago I had a similar issue. It was a result of a majorly bad rescue fuel issue...long story. At any rate I got a remanufactured MAF sensor from Napa. A few days later, same thing. Exchanged it, few days later, same thing. Exchanged it, few days later, not only is it bad again, but the car was bucking and then died completely. Tow it to a dealership since I had tried many things (I had several OBD 2 codes through the process...like I said, long story). Dealership said it started up fine, but MAF is bad. Great. So in the end I take the 3rd one back to Napa, pay the extra $30 or whatever and get a brand new one. The problem was solved after that.
    Good luck,
    Marianne
  1. Why is my MAP sensor causing my car not to start?
    By 1998gpgt in forum General Tech Discussion
    Last Post: 05-11-2008, 06:20 PM
  2. Cam sensor dowel?
    By Andrew_99GTP in forum General Tech Discussion
    Last Post: 04-20-2008, 07:54 PM
  3. Which O2 Sensor Tool?
    By IndeedSS in forum General Tech Discussion
    Last Post: 04-15-2008, 10:34 AM
  4. New CHEAP upgrade MAF sensor!!!!
    By Trannyman95 in forum Off Topic Discussion
    Last Post: 12-27-2007, 12:56 AM
