Thread: Spark Plug tips gone!!! UPDATE 2/6/2011
Page 6 of 6 FirstFirst ... 456
Results 101 to 112 of 112
  1. #101 Re: Spark Plug tips gone!!!
    Jul 2008
    sumter,south carolina
    Do eeeeet. With a small ass pulley.
    02 GTP with mods 05 GP for DD
  2. #102 Re: Spark Plug tips gone!!!
    Don't really need much tuning for ported heads as much as you would for E85...plus...it helps kill knock just about as well as E85 does...
  3. #103 Re: Spark Plug tips gone!!!
    Banned
    Sioux Falls, SD
    i just picked up a dhp tuner for 225 shipped
  4. #104 Re: Spark Plug tips gone!!!
    GT Level Member glanzergtx's Avatar
    Dec 2008
    Sioux Falls,SD
    Quote Originally Posted by miker56 View Post
    Should i go E85
    You should! BUT you better teach yourself how to tune and get some bigger injectors B/C with a higher compresson motor, cam, headers and pulley you WILL need larger injectors. might as well go with 65#ers.
    If your not going e85 get some 39# ford mustang injectors (these are pretty cheap) too. they plug right into the 04+ harness and with our fuel pressure its almost the same as 42# injectors.
    Just your normal 730whp 4dr family car.
  5. #105 Re: Spark Plug tips gone!!!
    Topeka, KS
    Quote Originally Posted by BoostnBlackGTP View Post
    when i 1st got my car i had a misfire and come to find out the tip on cyl. #4 was gone. but i have no damage to the engine from what i know. he may not have damage. u never know
    Same here it was after I did a 100mph run to find out if my tune took the limiter off. It burnt the end off the spark plug. No Damage to the motor was done. I had a bad missfire though. Changed the plug and its been fine ever since.
    I hate how you guys assume a engine is toast after someones car eats a plug esp burning the tip off. If the plug is smashed well yeah that's not good.
    Good luck on your build man. Looks like alot of fun!
  6. #106 Re: Spark Plug tips gone!!!
    Quote Originally Posted by rynoman03 View Post
    But, you've never had the head off...so you don't know. You can't say no damage was done because you don't really know...see what I'm gettin' at? Get a borescope and check it out that way then.
    We assume...because how else is the tip of a plug going to be totally gone...either there is something is a foreign object that smashed it to oblivion...from...example...a piece of piston...OR...the temps in the combustion chamber are so hot they melted the plug...and that wouldn't be to great for it either...just sayin'.
  7. #107 Re: Spark Plug tips gone!!!
    Topeka, KS
    I suppose. But if I had done any damage surely it would have Blew the F up after driving it for 4 years after it happend.
  8. #108 Re: Spark Plug tips gone!!!
    Banned
    Sioux Falls, SD
    I just pulled all my plugs and not burnt problem like before, Im pretty sure i was just running to hot of plugs!
  9. #109 Re: Spark Plug tips gone!!! UPDATE 2/6/2011
    Banned
    Sioux Falls, SD
    Pulled my egine due to oil coming out manifold, and here i found a chipped pistion on number 5. And all along ive been running with it lol, untill the ring went bad.
  10. #110 Re: Spark Plug tips gone!!!
    GT Level Member 98GPGT2D's Avatar
    Ontario, Canada
    Quote Originally Posted by 01gpgt01 View Post
    ......Your rear cats probobly clogged, and yes theres a gasket for the exhaust manifolds
    And who runs plugs for 100K miles
    Uhhh....the guy who owned the car I have before me. I changed them, and swear you could drive a transport truck through them.
    2005 GMC Jimmy 4x4 2-door 5-speed. CompCams 266HR Cam, W4M tune, 2.5" Exh, 246,000Kms (Sept 2012) Daily Driver.
    2002 Yamaha YZ125, Summer Toy.
    1997 GrandPrix GT 4 door White Ext, Pleather Int. 255,000Kms GF's Daily Driver.
  11. #111 Re: Spark Plug tips gone!!! UPDATE 2/6/2011
    Dec 2008
    Sioux Falls,SD
    JB weld and a new piston ring and your golden
  12. #112 Re: Spark Plug tips gone!!! UPDATE 2/6/2011
    Banned
    Sioux Falls, SD
    Quote Originally Posted by glanzergtx View Post
    There ya go dave, do that, then sell the car right away.
  1. Spark Plug Help
    By STP5593 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2010, 10:15 PM
  2. Spark plug suggestions?
    By projectGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-17-2009, 08:43 AM
  3. New Spark Plug sugggestions
    By RichCresci in forum General Tech Discussion
    Last Post: 08-25-2008, 08:32 PM
  4. Spark plug issue?
    By TurboKent in forum General Tech Discussion
    Last Post: 04-12-2008, 03:07 PM
