Thread: "No input to bank 1 O2 sensor"?
Results 1 to 11 of 11
  1. #1 "No input to bank 1 O2 sensor"?
    Wichita
    My engine light is on & I've had the car scanned by a few different ppl & each time it's scanned this comes up; "Code 1133, No input to bank one O2 sensor" I've replaced both O2 sensors & checked the wiring for any damage. Unless its by some chance a malfunctioning O2 sensor I'm at a complete loss whats causing this. I need to get this fixed it causes my car to run lean & sluggish. Has anyone delt with this problem & know what I should do?
  2. #2 Re: "No input to bank 1 O2 sensor"?
    Outer Space
    Sounds like your pacesetters are leaking. Do you have the y-pipe welded? I got the same code a year ago.
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: "No input to bank 1 O2 sensor"?
    Wichita
    Yep, my y-pipe is welded. So the code went away after you got your y-pipe welded?
  4. #4 Re: "No input to bank 1 O2 sensor"?
    Outer Space
    Yea, I was having issues with the Y-pipe at the time. Is that the only code you are throwing? I threw like 3 codes...
    My old post about it... http://www.grandprixforums.net/f81/t...nse-18156.html
    Do you still have an EGR? if so, make sure your not leaking there either.
  5. #5 Re: "No input to bank 1 O2 sensor"?
    Wichita
    It is the only code I am throwing. I checked under the exhaust & the y-pipe isn't welded all the way around. It leaked a bit on the topside so I just wrapped heat tap around it as a temporary stop gap. No leak for now.
    I don't have an EGR & nvr threw a code for it. Probably something to do with the ZZP PCM.
  6. #6 Re: "No input to bank 1 O2 sensor"?
    Outer Space
    Trace your wires on the o2 sensor again (no breaks or burns), and maybe put some dielectric grease (to ensure good connection on the plug).
    I went through like 3-4 o2 sensors troubleshooting that on mine.
  7. #7 Re: "No input to bank 1 O2 sensor"?
    Wichita
    I'll trace the wires again. Have thought about replacing the extension wire & the O2 sensor to see if that fixes the problem. Hadnt thought about using dielectric grease I'll try that too.
  8. #8 Re: "No input to bank 1 O2 sensor"?
    SE Level Member ASCStinger's Avatar
    Jan 2009
    Rochester, NY
    what brand O2 sensor? I made the mistake of using a bosch the first time around and wound up with the same code and warrantied the sensor twice before i tried an ac delco from rock auto. havent seen the code since
  9. #9 Re: "No input to bank 1 O2 sensor"?
    Wichita
    ^^^Both O2 sensors on my car are Bosch. I had my exhaust leaks welded shut & the code is still on. I ordered a Denso front sensor today to replace the front Bosch sensor. This had btr fix my problem.If it does not I may be forced to buy a new PCM.
  10. #10 Re: "No input to bank 1 O2 sensor"?
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    just delete the code. I had to. Its a common code when you do headers, its the switch rate on the 02 sensor
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  11. #11 Re: "No input to bank 1 O2 sensor"?
    Wichita
    Code always comes back within a day or two after being deleted. If the code is still there after i install the denso sensor im going to asume it is my zzp pcm. Maybe i didnt get my egr code deleted or something...
  1. "abs" and "trac off" lights staying on?
    By john9472 in forum Brakes/Suspension/Chassis
    Last Post: 12-03-2013, 09:38 PM
  2. "97" 4t65e-hd succesfully installed replacing the "00" 4t65e-hd
    By mikedinthecity in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-06-2009, 01:42 PM
  3. "Check CD" or "error reading cd"
    By pontiacprincess in forum Audio, Security & Visual Electronics
    Last Post: 04-04-2009, 08:22 PM
  4. Dynotech input shaft, 1" chain
    By UR LOSN in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-12-2008, 02:30 PM
