Thread: Radiator drain plug
Results 1 to 9 of 9
  1. #1 Radiator drain plug
    USA
    Can anyone describe what this looks like, as well as the location? Pic would be nice too.
    I am changing my water pump and need to drain the radiator. I read on the forums here that it was on the drivers side, on the bottom. The only thing on the very bottom appears to be the mounting point. A little above that on the back side appears to be some white type of plug, but it kinda looks like one of those screws you can only turn one way (except pretty big).
    thanks,
    2001 GTP Coupe
  2. #2 Re: Radiator drain plug
    Banned - Busted For Scamming
    Feb 2009
    drivers side bottom of the rad. you just turn it to loosen then pull on it , not all the way out, just until it starts to drain, then push it and tighten it back down.
  3. #3 Re: Radiator drain plug
    Charles City, IA
    Or it will strip out and then you just pull the lower hose.
    SMGPFC Two Nipple General
  4. #4 Re: Radiator drain plug
    KS
    Put a 1/4" socket wrench into that square and loosen it.
  5. #5 Re: Radiator drain plug
    virginia
    How many revs should the drain plug turn?
  6. #6 Re: Radiator drain plug
    Topeka, KS
    Quote Originally Posted by clubercp View Post
    Until you see fluid come out.
  7. #7 Re: Radiator drain plug
    Pennsylvania
    Is it a plastic thing, or a metal bolt looking thing like an oil drain plug?
    The ones on all my old cars were plastic green with a wing you turn...
    Are they the same on all Grand Prixs?
    Do any pictures of this exist? I havnt been able to find one, lol.
  8. #8 Re: Radiator drain plug
    just pull the hose from the water pump, and hold the hose up, so it don't drain, why drain it all? unless you need to. do put a catch pan under the car first tho.
  9. #9 Re: Radiator drain plug
    Charles City, IA
    I hope he got it figured out in under a year. .........
  1. Special tool needed for radiator drain plug on 2000 GP?
    By halfwit in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-18-2009, 09:31 PM
  2. Hello...and where is my oil drain plug located?
    By mbable in forum Introductions/Noob Questions
    Last Post: 04-06-2009, 12:18 PM
  3. Fan rubbing on the radiator
    By Infinity9999 in forum General Tech Discussion
    Last Post: 12-23-2008, 11:43 PM
