Thread: car wont idle. have to keep it running
Results 1 to 20 of 20
  1. #1 car wont idle. have to keep it running
    SE Level Member jj7ski's Avatar
    Jul 2010
    lansing, michigan
    97 grand prix gtp. Running fine then all of a suddent it won't idle. I have to keep my foot ont the gas to start and keep it running. As soon as I let of the gas it stalls. What is going on???
  2. #2 Re: car wont idle. have to keep it running
    Nov 2009
    Grand haven
    Try this mang.
    http://www.grandprixforums.net/fixin...lem-26549.html
    report back please.
  3. #3 Re: car wont idle. have to keep it running
    Jul 2010
    lansing, michigan
    Thanks I already know of this issue. I have just replaced the resistor. My car won't start at all when I'm cranking it over until I give it some gas. Whil its ruiniing it runs fine like there nothing wrong. While it cranks over without hitting the gas I smell gas. So its getting gas. So have to believe it something else.
  4. #4 Re: car wont idle. have to keep it running
    Jul 2008
    sumter,south carolina
    check your fuel pressure when turning over teh engine.
    02 GTP with mods 05 GP for DD
  5. #5 Re: car wont idle. have to keep it running
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    sounds like a bad fuel pressure regulator, pull the vac line off the regulator and see if theres gas in there
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  6. #6 Re: car wont idle. have to keep it running
    Jul 2010
    lansing, michigan
    That's what I was thinking. I pulled the line off there's no gas in it. Although when I turn the key on the igniton it does maker noise that Is noticeably louder than it has been. Is this still possibly the regulator? He iac is brand new so it can't be that. I replaced the tps sensor wth an older one I have and still no change.
  7. #7 Re: car wont idle. have to keep it running
    Jul 2008
    whens teh last time fuel filter has been replaced?
  8. #8 Re: car wont idle. have to keep it running
    Hagerstown,Md
    Only way to know for sure is to test fuel pressure
  9. #9 Re: car wont idle. have to keep it running
    Jul 2010
    lansing, michigan
    Fuel filter has been replaced a couple months ago. I just put this engine in a few months ago so I have been replacing parts to get it to run good. I bought a used engine so I don't know exactly the mileage of everything on it. Ok ill have to rent a pressure guage from autozone then. The fuel pressure should be upwards od 50 psi correct?
  10. #10 Re: car wont idle. have to keep it running
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Test the fuel pressure. Make sure it's around 45-50 psi. If that's normal, try cleaning your MAF sensor. I had the exact same problem, and the MAF sensor turned out to be the culprit. Make sure you use MAF cleaner or electrical grade contact cleaner.
  11. #11 Re: car wont idle. have to keep it running
    Jul 2010
    lansing, michigan
    Well I changed the pressure regulator. It took a few cranks and feathering the throttle, but now it starts up and idles fine again. I hope it the cure!
  12. #12 Re: car wont idle. have to keep it running
    Jul 2008
    awesomeness, glad ya got it fixed... i figured it had to be fuel related.
  13. #13 Re: car wont idle. have to keep it running
    Jul 2010
    lansing, michigan
    Thanks for all the help! I never knew these forums could be so useful. So how likely the is the regulator being the cause for my car running lean and making the manifolds glow?
  14. #14 Re: car wont idle. have to keep it running
    Jul 2008
    Its a possibilty if it still glows now. U could have a clogged cat converter also.
  15. #15 Re: car wont idle. have to keep it running
    Glowing manifolds if a clogged cat...get that sh1t taken care of...as...find a local that doesn't care...cut it out, gut it...and weld the empty converter case back in so it looks like you've got a converter when you really don't...and BAM...better performance AND MPG's...and you never have to worry about a clogged cat screwing with your motor.
  16. #16 Re: car wont idle. have to keep it running
    Jul 2010
    lansing, michigan
    My cat converter is removed. I keep getting ses codes for o2 bank 1 lean. I'm getting good fuel pressure. Its getting about 45-50. Althought when I turn the key it goes up tro 50 and then steadily goes down. When I start it, it stays at about 45. Is the igniton only on, decrease in pressure normal or do I have an issue somewhere?
  17. #17 Re: car wont idle. have to keep it running
    Hagerstown,Md
    02 bank 1 lean =vacuum leak 99.999999 percent of the time. was the code left over from maybe the FPR issue? Fuel pressure seems good now
  18. #18 Re: car wont idle. have to keep it running
    I'd bet some of the lines are rotted anyways...
  19. #19 Re: car wont idle. have to keep it running
    Jul 2010
    lansing, michigan
    I've reset the code a few times since I've changed the regulator. Well as far as I know. I don't have any vaccuum leaks. What's a good way to check for them? I don't hear any.
  20. #20 Re: car wont idle. have to keep it running
    Charles City, IA
    Carb cleaner. Idle will change when you hit it.
    SMGPFC Two Nipple General
  1. wont idle down
    By tedrowkj in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2010, 10:04 PM
  2. Running rich at idle, causing idle issues.
    By matt5112 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2010, 09:16 PM
  3. wont idle
    By grand2000prixgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-06-2009, 07:40 PM
  4. Car wont idle help!!!!!!!!
    By GINOSGTP in forum General Tech Discussion
    Last Post: 05-10-2009, 06:30 AM
  5. 3800 wont idle?
    By runn141 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-03-2008, 03:38 PM
